Results 1 to 15 of 21
Thread: How to easily turn off the ABS light permanently
    '99
    edit
    2001, Proton Yellow, #0580
    You must not need an emissions sticker - here in Atlanta your VX would pull a code and fail the emissions. At least that's what I've been led to believe. Those of you thinking about doing this had better check local regulations if there's an inspection involved.
    -- John
    John Eaton
    Original Owner
    2001 Proton Yellow #580
    Atlanta GA
    "Metaphors be with you"
    '99 Ebony Black VX, 0339
    Exclamation
    Gene pool cleansing - I love it!
    Aug 2003
    99, black, 1628
    How...
    Could that possibly throw a code for emissions? Isn't that wire just a relay from the brains to the light telling it to trun on? Where and how would emissions come into play there?
    99 Ebony Black
    The Jersey Fish
    East Rockaway NY
    NYPD's Finest
    1999, Ebony Black, VX ,1976
    Quote Originally Posted by Thejerseyfish
    If the light is on there is a problem with the abs it will throw a code. If the light is disconnected and there is a problem with the abs it will still throw a code. When they do an emission test they hook it up to a computer and check for codes. Some states may require the abs to be working properly, and you will fail the inspection. shawn
    1COOLVX
    What Shawn said - here in Atlanta pretty much any code will cause you to fail emissions because the shop won't continue doing the inspection until the code is cleared - it's not that it's part of emissions, but that it's causing a code to appear. My thought was more general in that many states require a general safety inspection, where an ABS light would most likely cause a failure due to safety concerns. That's why I said you should check the local inspection regs.
    -- John
    I had the SRS light come on in my daughter's car. VA inspection requires the light to come on for 5-15 seconds (I'm guessing at the actual numbers) then go off. They don't bother hooking up the diagnostic computer to test for codes. If the light stays on - you've got a problem. If the light never comes on - you HAD a problem and fixed it like any good redneck. I assume that the ABS is handled the same way.
    Sounds like his fix would fail in VA then - since bending back the pin prevents the light from coming on at all (disabled power to it).
    -- John
    That's what I said - you just used less words. LOL
    '99
    As with anything you change on a vehicle, such as window tinting, changing light colors, adding wheels and tires that stick out past the body, a loud muffler, etc., check your local laws and regs first. There's no need to assume or speculate about ABS and inspections. Just ask your friendly local inspection mechanic about having the ABS light on or if it won't come on at all. That's pretty easy. Some state auto inspection procedures can be found online. Here's what I found for PA vehicles at www.pacode.com-
    That's not real clear, but it seems like even if the ABS light is on, as long as the brakes work fine, I'm good to go. I need an inspection by the end of October, so of course, I'll let ya know what happens.
    Mark
    '99
    As expected, my VX passed the state inspection today with no problem. Air quality is good in my area so there is no exhaust testing, just a quick visual inspection of emission controls.
    Afterwards I asked the inspection dude about ABS and he confirmed it doesn't have to be working as long as the brakes work fine without it. I could be wrong, but I don't believe an OBD scan would find any ABS codes anyway, or airbag and TOD codes. They're not related to the CEL and can't be read with a simple OBDII scanner.
    Mark
    Quote Originally Posted by deermagnet View Post
    I could be wrong, but I don't believe an OBD scan would find any ABS or airbag codes anyway. They're not related to the CEL and can't be read with a simple OBDII scanner.
    Mark
    correctamundo.. need to have the dealership programming stuff to read the abs lights, my abs light doesn't show up when i scan w/ the scangauge
    '99 Ebony VX #0038
    I've passed emissions testing in WA state with an ABS light on, and I know they check ODBII codes so it must not throw one.
    2001 Kaiser Met. Silver #0551
    Thanks for the tip! Mines been on for a year now and cant figure it out. Also you are correct, ODB II will not pick up ABS codes. If they did, why would you want to spend $75 for the dealer to read the ABS code?
    Also, link to the ABS switch?
  1. Dome Light doesn't turn on with driver door
    By eblank in forum VX Troubleshooting...
    Last Post: 11/30/2011, 04:52 PM
  2. Transmission Light Turn On And Hard Shift
    By MMOROLEON in forum VX Troubleshooting...
    Last Post: 07/30/2010, 04:45 PM
  3. spoiler tail light / hazard light question !
    By Spike in forum VX Talk...
    Last Post: 05/21/2007, 09:27 PM
  4. Dead short in Rear Light/Instrument light
    By Damien Jones in forum VX Troubleshooting...
    Last Post: 07/16/2006, 08:49 PM
  5. Replies: 16
    Last Post: 06/21/2003, 01:10 AM
