On for a year? My light was on for less than two days and I couldn't stand it anymore.Also, link to the ABS switch?
http://www.wtv-zone.com/markg/switch.html
Remove neg batt cable. Take apart the underhood fuse box and locate the heavy white wire under the ABS fuse. Cut it and loop it outside the box thru the relay and back. When you send power to the relay, no more ABS till you turn the ignition off and on again.
Mark
