Results 1 to 14 of 14
Thread: Oil Filter Housing stripped
    Sep 2007
    1999 silver 0962
    Hi All, and thanks for the info. I bought my VX about a year ago from a friend. I took it for its first oil change at a place called Oil Changers; that's where I suspect the stripping took place. It took them something like an hour to do the oil change.
    My friend suggested I take it to Jiffy Lube, since that's where he always took it, and so I did. That's where the guys informed me of the problem.
    I'm still driving around, there seem to be no visible oil leaks. But I'd like to get this dealt with. Does anyone know what part I would need to replace the oil filter housing, and how expensive can I expect this to be?
    Thanks!
    On the right side of the home page (towards bottom) there is a download section that has a pdf file of VX part list. If you look in there you can find the part shown in the engine section (kind of blurry but readable).
    The part you are looking for (34 in the picture) is called "adapter" and the part number is
    89714 93432
    Merlin at St Charles Isuzu has the part for $102.65 (if you mention you got the info from this forum). It's $120.77 otherwise.
    http://isuzu.stcharlesauto.com/Department-Parts.aspx is where you can get his phone number. Make sure you ask for Merlin - he's helped out a lot of us.
    Jan 2007
    VX Skeleton owner
    Thanked: 6
    Some of the time with housings like ours they use a threaded insert that goes into the housing and the filter. If this is the piece that is stripped, you should be able to get one super cheap as long as you know what the threads are. It is a double ended piece of threaded steel which may or may not have different threads on each end. I don't remember if the VX has one or not, but I can guarantee they would be a lot cheaper than $100+ dollars, probably under $5. It 's worth a shot at least.
    Arrow Was the guy wearing a "Carnac" hat ?
    I'd like to know, if the housing threads are stripped, how is it there is no leaking & you're still driving around...to determine it was stripped, it would have to be dis-assembled. No one in their right mind would re-assemble it after that.
    GET A SECOND OPINION...you must know someone locally who knows a trustworthy mechanic, or a mechanically inclined neighbor ?
    I agree with Dubster, the oil filter is easy to locate and if you are up to it and willing to make a little bit of a mess, I would say it is worth looking into yourself before you start dropping bucks....
    When threads are stripped, you can expect leakage, even if it is minimal, trust me, I know this from recent strippage experience! You should be able to tell if the threads are stripped just by feeling them, and a flashlight should definitely tell you more...
    Sep 2007
    1999 silver 0962
    You guys rock. I will look into this and report back with my findings. Thank you so much for all the help!
    Mar 2006
    2001 FOXFIRE 0579
    are you sure that there is even any oil in there????
    you might make sure before you drive around much more.......
    and welcome to the family.......
    Question
    Quote Originally Posted by vxlady
    Soooo...what's the verdict ?
    Did you & your VX go on to live happily ever after ?
    Was there actually no damage, & the lube shop was trying to rip you off ?
    Inquiring minds...
  1. Thermostat housing ?
    By little-ry in forum United Kingdom Special Topics
    Last Post: 05/01/2015, 03:24 AM
  2. help need thermostat housing
    Last Post: 08/08/2013, 03:53 PM
  3. abs ring bolt stripped
    By djvx in forum VX Talk...
    Last Post: 05/09/2011, 09:00 PM
  4. LED lights in foglight housing
    By yellowgizmo99 in forum VX Modifications...
    Last Post: 12/30/2010, 11:31 AM
  5. stripped lug stud
    By spaceCADETzoom in forum VX Troubleshooting...
    Last Post: 07/27/2009, 05:09 AM
