Hi, I'm new around here. I bought my VX about a year ago used; it's a 1999 silver model, 46,000 miles.
When I last had the oil changed, the guys at Jiffy Lube told me that the housing that holds the oil filter had been stripped. I've called around a bit and can't find a mechanic who has even seen a VX.
What I want to know is, what part do I need to get, what's the best place to get it from, and if there is anyone from the SF Bay area around here, I'd love to know who you work with for your VX repairs.
Thanks!
You should be able to tell if the threads are stripped just by feeling them, and a flashlight should definitely tell you more...
I and everyone else here would place the root of the problem in the hands of the "jiffy lube" places that did the stripping in the first place. Many horror stories occur at their quickie lube shops. I would also recommend doing it yourself if possible? $20 and 20 min. Just prepare ahead of time for a smooth and less filthy experience. I would be a little more hesistant in your case as it would be a little tougher with stripped threads, and probably not a good chance to learn. Unless you had someone help you. I hate to demand something, but DO check your oil before every trip for awhile, or mark the mount and the filter with a mark of some sort to see if it becomes unthreaded. Its for the sake of your engine.
