Grrrr. this morning on my way to work vx was driving fine, suddenly lost its oomphhhh, check engine light comes on flashing.. I pull off the road, shut it off, say a few choice words, and call the hubby to say help. He says, try turning it back on, so I do, it starts up fine, check engine light still on not flashing. I decide to limp it back home. Runs semi ok, have to go up a big hill, again runs crappy and check engine light starts flashing, pull over and shut it off again. I waited a few minutes and started back up - got it home. Long story short....
hubby took it in and had the codes read.
1171 -
302 -
137B- and
157B
any ideas on where to start? In the last two years I've had multiple problems with the carbon build up. Put in new EGR, cleaned EGR every few months. Had new intake manifold gaskets put on, new timing belt etc. I have to add about a quart and half of oil in between oil changes every 3000.
I probably would have sold my vx by now if it wasn't for you guys on here.
Thanks for all the help and info!
Jody
