no problem costi!
if its running as poorly as i can imagine it might be, and its very far to the mechanic, you might consider gitting it towed, as to not leave you stranded for the gators to git!!! lol at least have someone follow you, if you do decide to drive it in.
agian, good luck with it. hopefully it is an easy fix, and youll be back on the road in no time.
