Results 1 to 15 of 18
Thread: Flat tire - spare size question
    Mar 2006
    Quote Originally Posted by Anita
    My truck is running tires 255.55.18. I have a spare wheel that has the stock 245.60.18. size bridgestone.
    I have a flat on a rear wheel. Can I safely put the stock spare on without the truck bucking up a storm? It needs to get home 10 miles and back.
    THE stock does sit taller so I am hesitant to do it without asking. HELP!!!
    Should be no problem, Anita. BUT! Spare tire can only be installed on the front! So, put spare on the front instead of one of the good one, then put good one instead of flat.
    1987 AMC Eagle: stock
    Thanked: 7
    Thank you everyone for the good advice. I REALLY did not want to drive the truck with the donut on so I had it flatbedded to a repair shop. Against my better judgement, I left it in an open lot at the shop overnight. Boyfriend had to hand me a couple of gin n tonics to calm me down and get to sleep. All was well in the morning - truck was okay. Unfortunately, the tire had a rather large hole on the inside side wall - so no repair could be done. A replacement shall be arriving this afternoon. Also I ordered a full size spare tire to be mounted on my spare Isuzu wheel. I should have done that from the start, then I wouldnt be whining about the donut...
    Anita
    2000 Ebony #263
    AnitaProtich.com
    anita since youre getting two new tires anyway i would recommend taking both rear wheels off and putting both new tires on the rear of your vx.. then using the one in good shape as your full sized spare... that way there is 0 differnce in your rear tire heights
    Thanked: 7
    Do you think the new tire paired with one with about 9K miles on it cause a problem?
    Thanked: 7
    Okay, so I have a new Kumho 255/55/18 on the left rear. I am noticing a slight whine while coasting - just like the whine I get when i have a low air tire. The kumho definitely has more knobby tread.. my Nitto has the flat street design.
    Next question: Do I buy another Kumho and run two new tires in the back with the Nittos on front, or do I buy a Nitto and replace the Kumho (leaving the Kumho as an emergency spare)? If the latter, would the truck react to a new Nitto and a used one on the back?
    Mar 2006
    It is bad for transmission if you have tires with different threads because of different contact with the road, so it is better to order the one you already have on the rest 3 tires and use different thread as instructed for donut. Otherwise you have a chance to kill your limited-slip differential so it become regular open differential or you might have TOD/ABS to fail in some cases.
    Thanked: 7
    Yesterday, I spoke with my mechanic and he thought it was a bad idea to have tires with very different tread patterns on the truck. The differences of "wander", i.e. how the tire tracks can cause unusual wear on the tires and a potential problem in general for the truck. Replacement Nitto should be coming this week and the Kumho will be placed on my spare rim for emergencies. Thanks to all for good advice and a great discussion about spares.
    Epilogue: New Nitto was put on and the whining stopped. All is well with the world. Maybe I am super sensitive to sound but its interesting that same size tires with some difference in tread wear and pattern can create enough change in the mechanism to produce unfamiliar sounds.
    Dec 2002
    2001 Ebony 0177
    Unless they are gumball re050s or you drive really, really hard....no.
  1. Tire Size Question: Gearing and fender cutting
    By frisbee in forum VX Modifications...
    Last Post: 09/11/2015, 08:53 PM
  2. Replies: 4
    Last Post: 06/08/2008, 10:51 PM
  3. Spare tire question ???
    By psychos2 in forum VX Talk...
    Last Post: 05/02/2007, 07:59 AM
  4. Tire size question....
    By SRCHN in forum VX Talk...
    Last Post: 11/03/2005, 08:19 PM
  5. Running with the spare tire question
    Last Post: 04/25/2005, 04:43 PM
