Results 1 to 15 of 18
Thread: Flat tire - spare size question
    just checked some info... the stock spare is 165/90/17 which is roughly equal to 28.7" which is smaller than the stock vx tires... and smaller than your tires as well... so long as you put the spare on the front and move one of your front wheels (preferably the one on the same side of the vehicle) to the back you shouldnt be far from the intended use of the spare
    Arrow
    I'm with ETL...rotate the front to the rear & install the spare on the front.
    Then take it easy on the way home.
    Mar 2006
    2001 FOXFIRE 0579
    i have used the fix a flat, and it does work on some flats/punctures/air leaking from chrome peeling....however, the guys at the tire shops hate the mess it leaves on the inside of the wheel.
    i did have to run the spare, on the front, and the way it steered, i didnt want to go very fast. take the back roads nice and slow, and try not to notice everyone looking at the bright yellow spare
    be safe
    2001,Ebony,VehiCROSS,1092
    Anita - know your problem was yesterday so you've probably already driven it home - but....seems to me you could pull the fuse for the TOD and eliminate that as a worry? I would have the same problem as you since I have that size tire as well - that was my plan if I ever had to run on the spare (pull the fuse). Also - somone mentioned putting the smaller tire on the front - I think I remember reading from someone here that was a definite no-no with the TOD (unless maybe you pulled the fuse?).
    Anyway - let us know how it went for you with the spare - I may find myself in the same situation one day!
    Arrow
    Quote Originally Posted by Raque Thomas
    Check me if I'm wrong here but...
    The TOD system senses rear wheel slip & transfers power to the front...wouldn't two different size tires on the rear be "sensed" as wheel slip ?
    Also, wouldn't two different size tires on the rear axle be turning at different speeds, eventually burning up the LSD clutches ?
    yeah spare wants to go on the front.... its even printed on the spare tire itself that you are only supposed to put it on the front and the stock tires are like 1/2" taller than anita's
    Mar 2006
    2001 FOXFIRE 0579
    i KNEW i read that somewhere, and since i dont have an owners manual, i figured i read it on the wheel cover, or a sticker somewhere back there.
  1. Tire Size Question: Gearing and fender cutting
    By frisbee in forum VX Modifications...
    Last Post: 09/11/2015, 09:53 PM
  2. Replies: 4
    Last Post: 06/08/2008, 11:51 PM
  3. Spare tire question ???
    By psychos2 in forum VX Talk...
    Last Post: 05/02/2007, 08:59 AM
  4. Tire size question....
    By SRCHN in forum VX Talk...
    Last Post: 11/03/2005, 09:19 PM
  5. Running with the spare tire question
    Last Post: 04/25/2005, 05:43 PM
