Has anyone installed this on their engine? If so i would like some input im thinking bout getting it but for 250.00 i want to make sure it is worth while. Any tips or suggestions are helpful. Pics as well would be nice.
I just got mine in the mail and here's my review so far (*haven't installed it yet):
1. Its big - lot bigger than you would think, even knowing the measurements. I haven't had time to fit it up yet but hope to this weekend.
2. When I got it and opened the box, the filter and shield were assembled and put in a sealed bag - removing the bag the shield was all smudged up and taking off the shield was tough - turns out the lip where it inserts had a small bend in it. Removing the filter, I noticed that 3 fins on the venture were broken off - wtf!??!! I then noticed that there were some breaks in the filter and was convinced that I got a return or something. Then I looked closer and realized the tears were from the rivets they used on the inside - why they didn't use smooth rivets I'll never know.
3. The filter may be good, but the overall quality I thought was lacking - the fact that the "venture" had broken fins, the bent lip, banged up and smudged cover and light tears on the filter material all scream "rush job" or "crappy chinese import" - I haven't emailed Tone yet and am sure he wasn't aware of anything being amiss - wanted to take some photos first. I'll post them here when I do.
4. I haven't corresponded with anyone else who bought it so I'm not sure if the issues described in #3 above were specific to the one I got or is indicative to the product - we'll see what happens when I contact them (or Tone).
5. You may want to wait until I get things resolved until you commit to buying one - they're rather expensive and at this point I'm rather crestfallen - everything hinges on the customer service aspect now. I'm emailing Tone with this post.
-- John
OK This is my opinion of this device. I have a lot of years of tuning cars behind me and I say that as far as performance goes, this thing is BS. There is only so much you can do about the volumetric efficiency of an engine, BEFORE the valves, combustion chamber and exhaust. A supercharger is an improvement, but swirling the air around isn't going to do much to improve on that. Save your money. (rolls eyes and shakes head)
Funny that there is ZERO data about any kind of performance improvement on tonemonday.com
I want to see some HP numbers before and after install.
Thanks for all the help.
Hey Dino,
The "twister" or what Green refers to as a "venture" IMHO doesn't do anything - it's the length and surface area of filtration, the quality of the filtering media, and the heat shield that your really buying here. I thought that was understood by everyone considering the purchase - even then the size of this unit probably wouldn't do much for a non-SC engine. My concerns about the fins being broken were more about build quality and less about how it would affect performance. You're getting a mongo filter here stuck on a huge pipe - combine that with a supercharged engine and wide exhaust and there's no doubt about a performance gain.
On that last topic, unless you open up your exhaust, putting on a performance intake wont do much for performance - it will eliminate some restriction on the intake side, but without doing anything to the exhaust you're really wasting the benefit of having it (though it does give the engine a more aggressive "sucking sound" under the hood). The real performance gain comes when you change out both the exhaust and intake.
-- John
OK I can see how more filter area would help.
Gee Dino, in your few short months on here and your 22 threads, you're quick to start criticizing. Had you searched and used your head, you'd have found that there IS dyno info on changing from the restrictive stock airbox to a filter with a larger surface area and even moreso with a blown application. True a better exhaust with a better intake arrangement is even better but the stock pipe and muffler does NOT flow all that it can. More air in will send more air out, restricted or not.
When you can start providing info that is helpful and backup by FACTS, you might really be credible. Until then, your 'years of tuning experience' are just hot air.
Now your test light writeup (and other idle musings to hear yourself talk) were funny - all cars draw some current rest - maybe you should disconnect the battery everytime you park un unplug all the fuses......
As for the filter being damaged, **** happens to all manufacturers and can slip out. Had he simply notified me, it would have been replaced right away. Green products have always been above average in quality and are superior to K&N.
So from now on, no one say or think anything unless first consulting Tone.
I have to backup Tone- hes not in it for the money. Hes here to help us all out, and if he felt that a product didnt help performance, there is NO way he would sell it.
In fact, I was going to buy his turn signal light conversion kit a while back, and instead he directed me to a way to do it for free- not the sign of someone whos just selling junk and in it for the money.
Tone's not in it for the money?! That's rich, creeg. That's a fairy tale. Your mother does things for you out of love - Tone just wants your money. I'm no fan of his, and it's not because of what he sells - it's because of his "Here's my deal - take it or go f--- yourself" attitude in doing business. Case in point...Originally Posted by creeg
Tone charged me $75 for a supercharger throttle cable bracket and another $40 to overnight it (for a 2-3 ounce part!) because he knew had me over a barrel - my VX was disassembled in a garage waiting for the bracket before it could be brought back to life. Yowza!!!
Now, this is the same throttle bracket that others have been complaining for years that they never got with their S/C kits, but Tone made it out like he was doing everything in the world to get the parts out of "evil, uncaring" Alpine.
Did you catch the implication in that? Many VXers here have paid Tone thousand$ for S/C kits that did not come with the brackets (among other parts), and never got them out of Tone - meanwhile he just so happens to find one and charges me $75 plus exorbitant shipping for it, instead of giving it to one of the many customers who already paid for it and never got it.
Tone, you have a lot of nerve (and no grounds!) for blasting away at Dino like that. There is nothing he said that isn't generally true of any filter kit, and I looked on your site just now - there is no dyno graphs on your site for the Green filters. The closest thing I was able to find was a dead link here to to a graph that used to include the dyno curves for the S/C before and after adding in the PV exhaust - JUST LIKE DINO SAID.
And that's all FACT Tone - with a paper trail behind it. Your ridiculously-quick defensiveness speaks to your insecurity about your products. You have been portrayed as some sort of all-knowing VX god here, but I find that characterization laughable.
And you don't even own a VX anymore...
..and in the left corner, wearing black cut-offs, TONE! ...and in the right corner, wearing, ...oh i dunno.. - I'm going to get popcorn and enjoy the show.![]()
Sorry lizrdman. this thread has taken a wrong direction........
I held my tongue for a long, long time, but this "Tone is the greatest thing to ever happen to the VX community" stuff... well, I just couldn't stand it.
Wow i just wanted some simple opions and paperwork result tests and pics now look what ive done
It wasn't you, man. As with any online purchase, you win some, you lose some. Some people have had great experience with Tone and some haven't. That's all this thread turned into - an outlet for positive and negative feedback toward Tone. Oh well, what ya gonna do?Originally Posted by Lizardmen3477
If you decide to buy now, you might get a discount!
Good or bad opinions not withstanding I gotta put in my two cents worth here. I've watched the man, numerous times in blazing summer Texas heat, install items owners have purchased from him and not charged them a dime or asked for help---ever. I promise you folks that should you ever have the opportunity to meet up with Tone at a group VX function you'll walk away with a different opinion than the mud that's being thrown on this thread. Let's put this to rest-we're all a little better than what's being posted here.
IMHO
George, Cary, & Roxie the English Bulldog..''99 silver #1897
