I recently took my VX in because the ABS light came on and the TOD Check light was flashing. The first code said the Electronic Hydraulic Control Unit was bad. I replaced it for about 150 from a junk yard. That cleared the EHCU code. The other code is for the Rear differential sensor. (Repair shop called it the Rear Differential ABS Sensor) do they mean the rear differential speed sensor? They said it would cost $585 new from Isusu. Is there anywhere I can buy the part cheaper.(www.car-parts.com) Does anyone know the exact name of the part I am describing?
Much Thanx
