Results 1 to 3 of 3
Thread: TOD Light ABS Help
    Oct 2006
    2001,Dragon Green
    TOD Light ABS Help
    I recently took my VX in because the ABS light came on and the TOD Check light was flashing. The first code said the Electronic Hydraulic Control Unit was bad. I replaced it for about 150 from a junk yard. That cleared the EHCU code. The other code is for the Rear differential sensor. (Repair shop called it the Rear Differential ABS Sensor) do they mean the rear differential speed sensor? They said it would cost $585 new from Isusu. Is there anywhere I can buy the part cheaper.(www.car-parts.com) Does anyone know the exact name of the part I am describing?
    Much Thanx
    Jun 2007
    2001 IRONMAN #0685
    Arrow What to call it?
    As an ex Ford parts person for 30 years. I'd call it a differenial speed sensor. They are also used on some vehicles to supply info for the speedometer. If you are doing a car-parts search, try a rear axle search. I'd bet it's the same on a Trooper, so try that axle search and call whoever comes up and ask them to check the axle housing for it. They are usually mounted on top of the differential into the case. There's a small ring gear inside whose spinning teeth are what the sensor reads. They can also be located at the axle end, picking up the ring mounted on the backside of the hub and rotor.
    '01 Ebony #0939
    Any chance there's an electrical connector for the sensor that just needs to be cleaned?
  1. Help with wiring light acces. to dome light
    Last Post: 11/24/2013, 09:49 PM
  2. Battery Light, ABS Light, No Power
    By TimG in forum VX Troubleshooting...
    Last Post: 03/22/2012, 09:23 PM
  3. Rear cargo light + underhood light
    Last Post: 05/29/2010, 09:00 AM
  4. spoiler tail light / hazard light question !
    By Spike in forum VX Talk...
    Last Post: 05/21/2007, 09:27 PM
  5. Dead short in Rear Light/Instrument light
    By Damien Jones in forum VX Troubleshooting...
    Last Post: 07/16/2006, 08:49 PM
