Page 6 of 8 FirstFirst ... 2 3 4 5 6 7 8 LastLast
Results 76 to 90 of 119
Thread: Common VX problems you'd like Isuzu to resolve.
    May 2003
    Cool documentation of problematic ownership
    #1 All four wheels flaking on the backside @ around 20k miles.
    (No action taken since I heard about 12k warranty.)
    #2 Passenger side Headlight gasket came loose.
    (Fixing myself)
    #3 Passenger side window slow to raise/binding.
    (Dealer said they corrected and lubed rails under warranty; Problem resurfaced within a week. I have had good success with spraying both window tracks liberally with silicone spray about once every 60 days. Eventually when warranty expires
    I will probably follow the route of that God of a VX'er Phines
    and apply his expertise.)
    #4 Both front stock(KYB) shocks bad.
    (Dealer agreed both front shocks bad; replaced under warranty)
    On a humorous note; I think you people jinx me 'cause I never have a problem until AFTER I read about yours! My windows were fine until I heard about yours! Stop the Madness! Renounce the Curse!!!;eekp;
    Signing the petition....
    May 2003
    '99 Astral #1613
    Window problem, of course. This is not the only problem I have with mine, but it is the only one thus far attributable to manufacturer defect.
    I have a small crack in my door panel from someone evidently having been inside the door to fix the windows at least once before, so that's the dealer's fault. Wish I had the previous owner's number or something to verify this happened after they serviced it for that. Not impressed with this dealer (the same one the previous owner had it serviced by at all the proper intervals) so far and would love to make them eat the cost of fixing that, 'cause I just know that's what happened.
    Jun 2003
    2001 Proton Yellow 1449
    Peeling crome rims
    I have about 6,750 miles on my 2001 proton VX and noticed the rims are peeling crome and the headlight gaskets are comming loose. Everything must be covered due to low millage !!! Have an appointment Aug 1st to address problems.
    Larry
    I # 61!
    Knowledge is power!
    2001, Black/red VX
    Ebony '01 Vx
    My list of problems:
    1: Hood insert crack
    2: Head light seals (both)
    3: slow windows/binding (replaced motivators both)
    4: Seat falling apart (drivers, Replaced)
    5: Hood insert cracking again. This time I had them let me install with the tech. They were not wanting to do this but let me in the end. I think the crack is do to improper torquing as when the tech was tighting it down I had to chew him out for "cranking it down" no torque wrench, nothing
    6: Bad center console latch thingy. and the darn thing was REALLY loose overall. They replaced the assembly then I had to unbolt and reattach it (they didn't put the right bolts in). Always take pictures of your vehicle before you take it in and after.
    7: Crack door trim (both sides) from when they replaced window motivators
    8: Dents in passenger door from window motivator replacement. How the heck they managed that I have no clue.
    Santa Ana Isuzu sucks.
    Dec 2003
    1999, Ebony, VX, 1865
    1999 Ebony
    Problems so far:
    1. Driver's side window motor
    2. Passenger's side window motor
    3. Peeling/flaking windshield wipers
    Jun 2003
    99, Ironman VX, 1455
    1. CD Changer
    2. Driver/Passanger Window Motor
    3. Headlight Liner coming off in wind
    4. Peeling flaking rims
    -The Rave-
    North Carolina
    2001,silver,906
    I seem to be having the same problem with the drivers side window going off the track and binding..The headlight gasket's and the wheels pitting on the inside (minor pitts)...I will NOT bring my V-Cross to a dealer for simple repairs or service ..If my engine or something important breaks ,I have to, I will walk around the car with the service guy and note the two minor scratches that I have,and the perfect interior.. Tony B
    Jun 2003
    Vehicross problems
    Got everything fixed under warentee from Hassett Isuzu in wantagh Long Island. They fixed peeling rims, headlight gasket and peeling front lower window cowl (near windshield wipers), and gasket above door on roof (clip broken).
    The only problem now is the drivers window is moving slowly but a shot of silicone grease has a quick fix for the moment.
    Sep 2003
    2000 Ironman 0591
    1. Egr valve 3-times since Sept. 03
    2.Egr tube 3-times since Sept. 03
    3.Power/Winter button 1 time
    4.Peeling wheels
    I love my VX but I had to fight to get some things taken care of that should be included in my 72 mo optional warrantee.
    Jul 2002
    99 Ironman
    What happened to your power winter button?
    Sep 2003
    2000 Ironman 0591
    The button still worked sort of...... The winter button would not click and lock into place but the power button still worked fine. Is this what happened to yours
    Jun 2003
    2000 vx dragon green 0044
    HAMILL CAMEL
    THAT'S ALL THE WINTER BUTTON DOES- 3RD GEAR?
    I CAN DO THAT MYSELF AND KEEP IT THERE PAST
    20 MPH- I HAD HOPED THAT IT MAY HAVE TRANSFERED
    SOME MORE POWER TO THE FRONT WHEELS FOR A BETTER DESCENT/ASCENT ON ICE-
    NO WONDER I LOOK LIKE DOROTHY HAMILL DOING
    THE CAMEL ON THE ICEY ROADS UP HERE!
    ;eekr;
    ex-2000 Kaiser owner (#040)
    Re: HAMILL CAMEL
    20 MPH-
    I think you misunderstood what he said.
    What the 'Winter' button does is force the transmission into 3rd although you are at a standstill. You pull away from the stop in 3rd gear. You do NOT start in 1st and shift upwards. Therefore, you can't 'do that yourself.'
    Forcing the transmission into 3rd from a stop decreases the tendency to spin the rear wheels on the ice or snow as you pull away. This therefore decreases the chance that you might lose control of the vehicle and allow it to slide sideways into a ditch....or into somone else at the traffic light.
    Think ice. Think snow. Think slippery. Think reduced torque. You'll figure it out.
    ....sT
    What if the Hokey Pokey really IS what it's all about?
    Jun 2003
    UNDERSTAND THAT PART!
    GOT IT! - BEING A PHD I DO UNDERSTAND PHYSICS
    JUST WAS HOPING IT WORKED A LITTLE LIKE
    THE DOWNHILL ASCENT BUTTON ON A ROVER!
    SINCERELY,
    HALF-WIT
  1. is this exhaust problem common
    By djvx in forum VX Troubleshooting...
    Last Post: 06/15/2010, 12:43 AM
  2. Replies: 8
    Last Post: 10/12/2009, 02:30 PM
  3. Purchasing advice and Common Problems
    By twistedsymphony in forum VX Talk...
    Last Post: 07/14/2008, 11:21 AM
  4. We have something in common with a Jag.
    By kodiak in forum VX Talk...
    Last Post: 04/10/2008, 04:05 PM
  5. Driver Window Problems & ISUZU Dealers
    By BeeVenom in forum VX Troubleshooting...
    Last Post: 10/02/2004, 07:34 AM
