Results 1 to 7 of 7
Thread: The Juice Box
    '01, Proton, VehiCROSS, 0229
    Thanked: 15
    The Juice Box
    Does anyone know if this (or something similar) works?
    http://cgi.ebay.ca/Isuzu-Rodeo-Stylu...QQcmdZViewItem
    Someday down the road I will do more major mods but for now as $$ is an issue I was thinking of one of these....that is if it works.
    Ty
    Thumbs down
    "Installed it, started jeep and did a wheelie thru neighbors yard awesome thanks!"
    On that recommendation alone I'd buy two, just in case the first one went FUBAR.
    IMO, if it sounds too good to be true it most likely is...99% of the time these products are a complete waste of money.
    I'd like to see the inside of the juice box...just to see if it's got anything inside...post pics if you get one.
    Just my two cents.
    Nov 2002
    For that price you should try it out and don't forget to post video along with the results.
    Afterward, I'd like first dibs when you part out your VX.
    Seriously though, the most likely route we'll find to higher performance would be Megasquirt.
    Jan 2006
    Thumbs down
    From my understanding those "boxes" were originally just a resistor that intercepts and reduces the voltage signal to your ecu (i think the airflow signal)... Tricking the ECU to raise the fuel ratio per stroke... Those things are getting bigger and bigger (as in the black box). I remember this mod back when I had my DSM...
    A total waste of money... considering a resistor alone is like .89 cents or something... ooh dont forget the couple thousand to replaced your blown motor!!!
    2001 Proton VX #0690
    You're gonna want to pick up one of those Tornado Fuel Savers, too. Oh, and some 30-Weight ball bearings and ’bout ten quarts of anti-freeze.
    But they are upgrading it to "stage 3" and it comes in a cool limited edition black tuperware bowl! :laughr:
  1. Brake Juice: DOT3 vs. DOT4
    Last Post: 12/21/2006, 06:15 PM
