Results 1 to 5 of 5
Thread: Easy Huh!? Shock Install help...
    I have the passenger shock off but getting out between the top A-arm and the sway bar, how do you get it out??
    Help I need my car this afternoon
    TIA
    df
    face the mirror
    Without seeing what is in the way it's hard to say. Perhaps remove te nuts from the bottom of the sway bar links and rotate the bar out of the way.
    Dec 2004
    df - not sure exactly what you're getting at, but see this post:
    http://www.vehicross.info/forums/sho...0&postcount=30
    I posted info on how I changed my shocks a couple of years ago. Hope it helps!
    I haven't had to remove mine so I can't give any personal advice. Below are the 2 pages from the shop manual.
    Thanks for the response crew!
    I basically removed the sway bar links rotated the sway bar up and removed accordingly. Made alot easier/doable.
    Now the rears
  1. Rancho RS9000XL shock install
    By vxcp in forum VX Troubleshooting...
    Last Post: 05/18/2016, 01:33 PM
  2. Vendetta's Rancho 9000XL shock and Indy4x HD torsion bar install
    By Vendetta in forum VX Modifications...
    Last Post: 10/03/2012, 02:39 PM
  3. Easy Task for Most of You
    By nemo in forum VX Talk...
    Last Post: 10/29/2009, 09:05 AM
  4. Easy TOD off switch!!
    By kodiak in forum VX Modifications...
    Last Post: 06/04/2009, 10:02 PM
  5. Go easy on me I'm new!
    By tritonsmoon in forum VX Troubleshooting...
    Last Post: 02/18/2003, 03:04 PM
