Page 2 of 2 FirstFirst 1 2
Results 16 to 18 of 18
Thread: ABS Light????
  1. #16
    I am not sure how soon i can access a dirt road... but if i happened to be near an empty lot with dirt mounds i may give it a try for you. Though my ABS light is on and off as it pleases...
    ~*~Cece~*~
    ____________________
  2. #17
    May 2007
    2000, Ebony Black, ....
    Arrow
    Try this ...
    Pull the plug on the main unit under the hood. It lives on teh passenger side near the firewall, and it has several brake lines going into it. The electrical conector has a safety catch on the side that resembles a t-handle. pull it, and the plug will back itself out of the socket. Push it back in a few times. IF there is a bit of a bad connection there, this might clear it up. Just work it back and forth a few times then make sure it's all the way in and leave it. Take a test drive...
    It's that intermitent thing is why I thought I should post this. From a mechanic perspective, that is the FIRST thing I would check.
    Thanks for all the help.
  3. #18
    I have the same problem...
    It started in February 2007 and was intermittent -- the light going on and off. Eventually, it started staying on all the time. I suspect that this particular component is a weak link in the VX design. A lot of owners have complained about it.
    Did you know that Isuzu issued a recall for the ABS module in one of the Amigos -- 1998, I think? They did. But they didn't issue a recall for the VX. In any case, I've been driving safely without ABS for 6 months, but I intend to get it fixed with junkyard parts soon.
    I would caution those who take the attitude that "cars drove fine without ABS for decades and therefore this isn't a problem to worry about" with the following: Driving without ABS can expose you to a lawsuit if your vehicle causes an accident. The plaintiff may assert that you failed to properly maintain your vehicle's factory safety systems, and they could sue you for damages. We live in an era where this safety system is standard on new vehicles. A responsible owner should always maintain every safety system on their vehicle.
    Grant
    2000 Proton Yellow #756
    "THE UFO"
    Seattle, Washington
  1. Help with wiring light acces. to dome light
    Last Post: 11/24/2013, 08:49 PM
  2. Battery Light, ABS Light, No Power
    By TimG in forum VX Troubleshooting...
    Last Post: 03/22/2012, 08:23 PM
  3. Rear cargo light + underhood light
    Last Post: 05/29/2010, 08:00 AM
  4. spoiler tail light / hazard light question !
    By Spike in forum VX Talk...
    Last Post: 05/21/2007, 08:27 PM
  5. Dead short in Rear Light/Instrument light
    By Damien Jones in forum VX Troubleshooting...
    Last Post: 07/16/2006, 07:49 PM
