My TOD check light is coming on intermittantly, and when it does the front 2 wheel's are not lit at all on TOD display, and it drives and sounds like it's in 4 lo. By that I mean if I make a tight circle there is a jerking motion and loud noise from the front wheels. There are no error codes at all. In addition, my power windows stopped working but the fuse is good. All fuses checked look good. I do have a leaking rear brake cylinder needing to go in for repair but wouldn't think that would cause the TOD issue. Know it would not cause the window issue. I feel this will be a job for the shop but thaught I would throw this confusing electrical issue out there for some of you less technically challenged than I.
