Results 1 to 15 of 24
Thread: Custom Roof Rack?
    Dec 2002
    '01 Ironman
    Custom Roof Rack?
    I know that someone was fabbing up a roof rack that would accomodate a full size spare. I can't remember where I saw it, but it had the Vehicross logo on both sides of it. Is this still in the works?
    Dec 2002
    '01 Ironman
    OK did some more searching and found that multimediaman was the one working on this, however he has only posted once to the .info site. Does anyone know of an update on this old project?
    Dec 2002
    '01 Ironman
    If anyone has been following, I emailed multimediaman and here was the response.
    "Sorry for the delay, I was in the hospital for awhile very ill. I am going to meet with a manufacturer at the end of june to get the ball rolling. I will post the results of our meeting in July. Hopefully by then I will have a cost estimate."
    Mar 2003
    I'd be VERY intersted in this too... I want a fifth full size wheel and tire and wanted a rook mount rack for it. If anyone finds it, post or email me at rreed17@kc.rr.com .
    TTYL!
    Coach... aka Randy!
    Dec 2002
    '01 Ironman
    Here is the prototype drawings that were on Vmag
    2000 Dragon Green VX 0485
    With the VX OEM Towers at approx 28.5 inches on Center, I would think the way the proposed Rack is cantilevered at the front & back that it would have to be exceptionally strong to support loads such as a full sized spare.
    Mar 2003
    That would be pretty kewl IMO. I would like to see exact scale drawings of it and would moreso like to see it made. Would take care of lots of problems with my spare tire situation... don't know that my temporary spare will be too much use with my 285/60/18" Nitto's. I look forward to seeing/hearing more.
    TTYL!
    Coach... aka Randy!
    Oct 2002
    '01, Dragon Mica Green NO MORE, 1393 SOLD
    TTYL!
    Coach... aka Randy!
    It's useless. If you throw the temp spare on with your oversized Nittos, the ABS system (and probably TOD too) will throw a ***** fit.
    You guys know you can get a spare carrier for the Yakima Loadwarrior and Megawarrior right?
    '99 Astral #1977
    The Yakima spare tire carrier also works with the Thule Playpen.
    RichD
    The "spare carrier" that they sell can be made with $5 worth of hardware from your local hardware store! A long bolt, big wingnut, and a couple of 4-5 inch round metal plates with holes drilled in the middle. Lock it to the rack with a cable lock!
    Mar 2003
    Anyone have a link to said rack? BTW, why would this throw a ABS or TOD light to add this other rack and spare tire? How do these systems work? I mean, usually these systems mearly compare the front and rear wheel speeds to work... how would a shift of weight change that? I'm just curious.
    Thanks in advance. TTYL!
    Coach... aka Randy!
    Dec 2002
    '01 Ironman
    Coach, he was talking about using differant size wheels.
    Mar 2003
    Your saying that the ABS or TOD won't work right with my larger tires? Seems to have been perfectly fine since they have been on. I have put on around 2500 miles since my tires were installed and everythings good. What seems to be the problem with oversized tires? Am I missing something else here?
    Later!
    Coach!
    Dec 2002
    '01 Ironman
    He was saying if you were to be using your factory spare that it would be screwing the TOD and ABS up since you have oversized tires. In other words your factory spare is worthless now.
    Mar 2003
    Ahhhhhhhh... did I mention I'm blonde?! Yes I AM! I can be dense sometimes... but I'm over it now... thanks for the clarification... and the help on the issue.
    Later!
    Randy!
  1. Yakima roof rack clearance with sliding roof?
    By JULIAN911 in forum Ldub's After Midnight Topics
    Last Post: 03/21/2014, 02:35 PM
  2. Custom Roof Rack
    By Dumke in forum VX Talk...
    Last Post: 07/20/2009, 02:13 PM
  3. Custom Roof Rack Rail Covers...
    By nfpgasmask in forum VX Modifications...
    Last Post: 02/23/2008, 03:38 PM
  4. Custom Stainless Steel Roof Racks
    By Dino in forum VX Modifications...
    Last Post: 07/25/2007, 07:24 PM
  5. Replies: 7
    Last Post: 06/09/2005, 03:39 PM
