Results 1 to 6 of 6
Thread: Front Hood Spring
    Front Hood Spring
    I'm looking for the part the causes the hood to pop up when you pull the hood release lever in the cab. Right now I've got to pull the lever and have my wife lift the hood, or find something to keep the lever pulled while I run around to pull up the hood.
    Anyone know? I'm not familiar enough with the mechanics of the hood release to give a better description.
    Thanks in advance.
    Jan 2006
    I had the same problem as well,
    All I did was clean the dirt and old grease out from the latch mech. and sprayed some wd-40 and all was good. it has been 2 years now. no more stuck latch! That might save you several bucks and a huge headache.
    2001 Foxfire 1232
    Try turning the rubber bumpers on either side of the hood latch a 1-2 turns counter-clockwise. That and lubricating the hood latch may be all you need.
    Dec 2004
    Yes, the WD-40 will work wonders. The reason it doesn't pop up is not because the spring is weak, but because the latch mechanism gets so filthy and gritty that the spring isn't strong enough to overcome all that friction. I think almost everyone here has had this problem. Heck, I'm due for another cleaning, actually.
    Good luck!
    Apr 2006
    2000 dragon green 0496
    I have the latch problem too.
    I will try cleaning it and spray with WD40
    Makes sense! I'll give it a try when I get back home this weekend. Thanks.
  1. Spring Cleaning!
    By ohiovx in forum VX Talk...
    Last Post: 04/15/2015, 03:54 AM
  2. Looking for FRONT CLADDING, HOOD, BUMPER
    By highfall in forum VX Troubleshooting...
    Last Post: 03/20/2015, 05:03 AM
  3. It's 10 PM, do you know where your spring helpers are?
    By blacksambo in forum General Tips...
    Last Post: 04/29/2011, 11:54 AM
  4. Spring time!!
    By 99VX4x4 in forum VX Talk...
    Last Post: 03/21/2006, 04:35 PM
  5. Spring Training '05
    By Catch77 in forum VX Talk...
    Last Post: 03/01/2005, 08:31 PM
