Hi Guys & Gals - I installed my 912's a little over a month ago. After initial install there was a pronounced rattle coming from the back of the truck. I assumed it would go away after the springs settled. It has not. I can not see anything loose under there. Also, it is only on the little chatter bumps on paved road.
Any ideas? It sounds like the spring is rattling around under there but I can imagine that.
Thanks in advance!
