Results 1 to 6 of 6
Thread: How to check ABS Wheel Sensors?
    Aug 2004
    01, Kaiser Silver, VX, 1102
    Question How to check ABS Wheel Sensors?
    How do I check wheel sensors spoke of regarding ABS light coming on? Mine is off in morning when started and upon 5 mile drive is on remainder of day. Many have spoke of checking sensors for metal flakes etc. How do I do this before paying 90 bucks to Isuzu to hook to computer? Thanks
    Quote Originally Posted by VXNIT
    I have the same issue. Inquiring minds want to know!
    You can take the brakes off and examine the sensor rings on the back side of the discs and also the sensors on the spindle and rear axle housing. Removing the sensors can be a scary thing because of the brittle plastic. I have broken one because of this - before that, the wires popped out - after that the mounting bolt broke. I learned the hard way! AGAIN! The mounting bolts may be siezed due to rust and high temps. I would lube things up if you need to replace them and then use a socket and hammer to help tap them out the backside after removing the mounting bolts.
    Aug 2004
    Any pics to identify these parts available from anyone?
    Even better - have you ever seen this?
    http://www.vehicross.info/misc/vx_manuals/IV00_01.pdf
    Open the file. Then pick on the number of the section you want to go to and you are on your way!
  1. Oxygen Sensors
    By blacksambo in forum VX Troubleshooting...
    Last Post: 11/04/2013, 07:52 AM
  2. Removing TOD wheel speed sensors
    By IsuzuJay in forum VX Troubleshooting...
    Last Post: 08/06/2013, 09:41 PM
  3. One last wheel fitment double check
    By custom in forum VX Modifications...
    Last Post: 07/19/2007, 06:20 AM
  4. O2 Sensors problem
    By BlackVX in forum VX Talk...
    Last Post: 07/01/2003, 06:21 AM
  5. 02 Sensors- Better MPG??
    By xdfarrx in forum VX Talk...
    Last Post: 03/11/2003, 09:37 AM
