Alright, this goes down as the easiest repair I have done on the VX yet. The actually installing the bracket was way to easy. Getting the door panel removed - 5 minutes max. Finding the right size socket to undo the two screws (to tight for the screwdriver, afraid it would strip) - 10mm - 4 minutes. Pulling the window out (no guts, no glory) 30 seconds. Realizing the plastic clips were not even broken - doesn't count in total time. Scraping off old glue and cleaning window - 5 minutes. Gluing new bracket in place - 2 minutes. Letting it dry - as much as you feel is needed, I waited 2 hours. Reinstalling window and attaching the two bolts - 5 minutes. Testing and adjusting window - another 5 minutes tops. I am leaving the panel off a few days just to make sure all is good, but overall I am very pleased with how easy this replacement was. Thanks for making these.
I made one adjustment when installing these. I first put the window in and tightened everything down and the window was very sluggish towards the top. I lowered it loosened the bolts a half turn raised it up, all seemed good, and lowered it and tightened them up. All seems good.
Thanks to everyone who gave input on this posting. It really helped with the install. Mike
