That's the fundamental question... Does the design address the tilt problem, or could they be modified to allow for adjustments left and right?
If this is a permanent fix, I'm definitely in, and $49.00 shipped is more than fair.
In for a set! My passenger window sux, and the driver's side is getting wanky.
Let us know about the tilt adjustment factor, too, if you took that into consideration! Thanks for doing this. Nice work!
$49! I'm most definitely in!
When i made my first set i punched the mounting holes for Vertiacl Adjustments!!!! It didnt help the tilt problem at all..still tilts slightly!!!! Im working on a solution to the tilting but that will have nothing to do with the clips, the tilt has more to do with the play in the piece that connects to the cable !!! in my case anyways..............There will be holes for Horizontal Adjustments only.Originally Posted by rowhard
Tim
www.streetboutiquecustoms.com
Taking orders now for the replacement window clips
Link to the VX page is on my website just below the customergallery.
These mounting clips are slotted for Horizontal Adjustments.
Just starting to get these into production for you guys so bare with me please, I will be building these as fast as i can...
Tim Parker
Tim, I have had a few jar's of kentucky's finest, sooooooooooooooo,... maybe I'm not see your website below the customer's gallery. Anyway, made for horiz. adjustment, that means the tilt problem right? Some are in need right now, so will stay in touch since mine are well lubed, or is it me that is,... not sure right now, but it is the 4th so who gives a hoot.
Horizontal adjustment and "spacers" for the "play" is all the adjustments needed.Originally Posted by SBC
I'm glad your addressing the horizontal problem.
OK I still cant see where to pay. Under custmer gallery is nothing but VISA and PAYPAL logo's. How am I missing it?
THANKS STEVE
Tim,
It is good to hear that you have address my concerns. I think you have done a great job.
It sounds like the play in your window should be fixed with the washer "spacer" fix. I wish I was close enough to help you with that.
I tried the spacer fix.....still tilts slightly so im not happy.......LOLOriginally Posted by Bulldoggie
i would like to see the inside of another VX (in Person)and see if it is wearing on the track the same as mine...just to much play in mine! Will get a chance next week to pull it apart again and pull the whole thing out to see what i can do about it...
Thanks Bulldoggie
Tim
Like I said before SBC, we're in the same trade... and I guess our minds are alike because I see the Isuzu regulator the same way you do. IT'S CRAP!!
I have wear on the center alignment nylon parts. Bad design.![]()
A regulator with guide width of about 1.75" with a moment arm over 16" on three little points of nylon!!!!
To expect that to last more than a year or two without significant wear is nonsense. ALL of mine have hairline fractures in them at seven years old. ALL of the plastic tabs were broken. This was my fix.
So here we are, with all these window problems caused by three points of contact that aren't even close to the form following the function.
I'm also brainstorming a whole new regulator SBC. Should be fun to see how we each solve the problem.![]()
Thanks for all the help.
You guys are awesome to take the time to not only find a fix for a problem we all share but to share your fixes with us including detailed pictures. Thx
It is possible that the plastic guides on your lift arm track are worn beyond their porpose. most likely the one that has a thin slot that rides the edge of the track. (this is the one that controls vertical alignment) the other guide wraps around the other edge and holds the arm close to the track. You might pull the panel on the other door and compare the wear on the arm guides. I have no fix for these two plastic (nylon) guide pieces. If you cannot make your own, you may have to buy a complete regulator to get those pieces.Originally Posted by SBC
Sorry it's not a very good picture.
Yep same as mine to much play in that spot!.....Just gonna figure a way to fix that little problem of the guides by adding a roller to it or something like that......Just like with the clips I will build somthing rather then buying a replacement so i dont end up with the same problem a year or two down the road!Originally Posted by Bulldoggie
Tim
Great product!!!! Thanks Tim. Highly recommend fix...
