Results 1 to 15 of 29
Thread: Trailer Light Connections
    Oct 2006
    2001 Proton 0586
    Can I connect trailer lights directly to the wires inside the VX tail-lights without concern about affecting some computer function within the VX somewhere?
    Some previous vehicles I have owned required trailer light special adapters that protected any potential impact on other vehicle computer-controlled features. At least, that is what the trailer hitch sales person said.
    Henry
    2001 Proton VX #0690
    I don't know if it is strictly required, but Tone sells a trailer wire kit at http://www.tonemonday.com/vxparts.html for $24. It appears to involve a mystery black box.
    that sounds like a sales pitch for the adapter to me... i dont have a whole lot of experience with trailer wiring.. but ive wired just about everything else you can think of in a car and well.. brake lights and turn signals are just wires and switches.. no computer interaction that i know of.. the wiring tone offers is just connected in the tail lights and ive had no ill effects from it (of course i also havent hooked it up to a trailer yet) but ill go out on a limb here and say his trailer wiring.. like all of his other products.. works well
    Dec 2004
    '99 VX Astral Silver #0949
    The "Black Box" converts a three bulb tail / brake / turn light to a double lamp trailer light (trailer lamps turn filament is the same as the brake)
    Oct 2006
    2001 Proton 0586
    Thanks for the responses.
    Looks like I need to provide more details. The previous owner had already installed Tone's hitch and wiring adapter. However, there is something wrong - not enough voltage arriving at the trailer connector. I have confirmed that the correct wires have the right signals, but there is only around 7-9 volts, which is not enough to get the trailer lights on.
    To avoid disassembling the rear bumper clading, to get to all of the wiring, I was just going to go back inside the rear light housings and make some new connections and bring the wires inside the rear storage area. Then, when needed, I could let them hang out through the door gasket. Not pretty - but functional.
    Henry
    Lightbulb
    I'm pretty far from being any kind of expert when it comes to wiring...or anything else for that matter...but it sounds like your current "black box" may be malfunctioning.
    If you do as you say, & snip the wires to the existing trailer wiring harness & install a new one, this theory could be proven, one way or the other.
    Also, it could be as simple as corroded connections on the one that's there. Maybe a poor ground connection?
    Jun 2007
    2001, Proton
    Trailer
    I am new here but have owned a 2001 Proton from new. I always wanted the ability to use a trailer but the Owners Manual says the VX is not designed for Trailer use. Am I missing something. Any photos or spec on what people are hauling and weight limits? Where is Tone located and where is St Charles Isuzu they sound like good resources.
    Well it says it will if you use the "Does this fit my vehicle link" but I don't know how much you can really trust it. When I tried to hook up my cargo box with the wiring/converter that Tone provided, I had a similar problem to etlsport above, only that I got running lights, turn signals, but no brake lights. Took it to a trailer shop and they said that Isuzu's actually used a European style wiring system, so the converter need to be a 5-way instead of a 4-way (I think). Note that's the converter, not the plug - there are always four wires in the plug.
    Don't know if that helps much.
    1999, Ebony Black, VX ,1976
    The only reason we need a converter is because of the independent turn signal bulbs. And that is what that is for so it will work if hooked up correctly. shawn
    1COOLVX
    Towing a small sailboat
    I am in the market for a small daysailor or similar boat to sail on the Potomac and as soon as my VX gets out of the shop (in a month!!! AAARRGGHHH), I want to look into getting a hitch put on.
    Any advice?
    Thanks,
    Marc
    DeepSilentComplete :coolr:
    He postulated that cognitive simulacra might one day approximate component models of the psyche.
    Wait on Tom4Bren's updated Tone-style hitch, since the hope is that it will handle more tongue weight than what we all have now. Tom's down in Fredericksburg so you might even be able to get it installed at the same "welder guy" shop.
    Welder Guy's shop prolly ain't an option. I work with him at Fort Belvoir but his shop is alla way out at Colonial Beach.
    I'm a tried & true 'shade tree mechanic'. Yer welcome to the T4B pad some Saturday & we can get it done tho.
    I hope to re-install my hitch this weekend & get all the measurements needed to make the beefier hitch.
    Nov 2011
    99,Silver,Base,0079
    Wiring woes
    After issues with the old 4 flat wiring harness, I picked up a universal wiring kit that included the 5 -> 4 wiring converter box. The problem is that the trailer brake lights are coming on very slow, and very dim. The turn signals are not working at all. It appears like the trailer was not getting enough power fast enough. After comparing the voltage between my car and another working vehicle, I found that I am getting about 2-3 volts less on the brakes and turn signals than the working car. I even pulled the tail light and tested there. I appear to only get about 9 volts on the brake lights with no external wiring hooked up. My vehicle lights are working fine through. Any ideas???
    '01 Ebony #0939
    Quote Originally Posted by PA-99 View Post
    Aside from double-checking that you've tapped into the correct vehicle wiring (as follows) for your trailer harness, I would also double-check your ground connection. Make sure you are metal to metal (most surfaces are painted or coated in some way) with whatever connector you've used for your ground-wire to vehicle-chassis connection, or at least use a self-tapping screw that you are sure is tapping into some part of the VX's metal frame. There are also a lot of rubber grommets used on various pieces of the VX that isolate that part electrically from the chassis, so sometimes even though it may seem that a good ground connection is being made, that's not necessarily the case. A simple test meter check will let you know for sure.
    RT Turn Signal Wire Color (only avail on the Passenger Side): Green/Blue
    LF Turn Signal Wire Color (only avail on Driver's Side): Green/Blue
    Parking/Running Light Wire Color: Green/Red
    Brake Light Wire Color: Green
    Nov 2011
    99,Silver,Base,0079
    I'm pretty confident that I have the harness connected to the correct wires, as I am able to see in increase voltage when I activate the feature. When I test and get the low voltage, I am testing using the ground wire attached directly to the turn signal. That is also the ground wire that I am connecting the harness to. I honestly do not know how the lights on the car working, because they are showing less than 12 volts
  1. Tent trailer/overland trailer
    Last Post: 06/01/2014, 10:52 AM
  2. Lashing it to a trailer?
    By TexVeX in forum VX Talk...
    Last Post: 10/14/2011, 01:56 PM
  3. Tone's Light Adapter for Trailer Lights
    By ojmagg in forum VX Troubleshooting...
    Last Post: 11/20/2006, 11:03 AM
  4. 18' trailer
    By ThunderChicken in forum VX Troubleshooting...
    Last Post: 08/31/2005, 01:41 PM
  5. Trailer hitch brake light
    By webdog in forum VX Talk...
    Last Post: 06/09/2003, 10:17 AM
