I measured the distance on my VX from the peak of the wheels wells to the ground, and was surprised that the driver's side (both front and back wheels) was about 1/2 inch higher than passenger side. Is this normal for a stock VX?
I did this before installing new tires, and cranking the torsion bar a couple of turns the same on each side. Not surprisingly, both sides of the front raised equally (driver's side still 1/2 inch higher).
Should I try to level the ride height by adjusting the torsion bar, or is it supposed to be a little higher on the driver's side?
Thanks for the help. Rob A.
Or maybe they are compensating for the fact that there is almost always a driver in the truck and the springs sag???
