Results 1 to 3 of 3
Thread: air conditioning pump
    Sep 2006
    1997silverjapaneese1254
    after driving up all them rivers for the last 2 weeks the bearing in the air conditioning pull wheel is noisy their is a 10mm headed bolt in the center i took it out and tryed to pull the pully wheel off but its not budging is their something else holding it on or do i bring out the bfh next time ??
    May 2007
    2000, Ebony Black, ....
    You'll most likely need a new compressor. To get the pulley and clutch off you'll need a specialpuller. You have also exposed your timing belt and it's components to submersion.
    That's the price of driving under water.
    I'd also check the vents to your differentials. Maybe even crack open the drain plugs to check for water. Is your dipstick well sealed? how about the PVC gromet?
    There's a million holes that water can get into.
    Thanks for all the help.
    2001 Ebony 0177
    Yeah, you are gonna need a pulley remover. Coupla of bucks at the parts store, it's usage will be obvious. Great vids, hope they didn't cost too much in the long run.
  1. leather conditioning products
    Last Post: 07/24/2011, 09:54 AM
  2. Air conditioning question
    By Anita in forum VX Talk...
    Last Post: 08/25/2004, 09:58 PM
  3. Gas prices at the PUMP!
    By azskyrider in forum VX Talk...
    Last Post: 05/13/2004, 12:49 PM
  4. Met an ex VX'er at the Pump
    By Jonnie in forum VX Talk...
    Last Post: 08/19/2003, 05:22 PM
  5. Cladding Conditioning/Protection
    By omegavx in forum VX Talk...
    Last Post: 08/19/2003, 02:49 PM
