Results 1 to 15 of 17
Thread: popping/clicking noise
    OK folks,
    Post Moab, I have discovered that my VX now makes an audible popping noise, when backing up with my wheels cut to the left. I am thinking CV shaft but wanted some input here. The noise seems to be coming from the right side, underneath, and seems to be under the passenger side door toward the front end. Again, the noise only happens in reverse, and only with the wheels cut to the left more than half way.
    Any ideas?
    Thanks - Bart
    Aug 2006
    1999, Astral, Vehicross, 1619
    From my experiance with cv's I would say if it doesnt happen when you make a u-turn then it probly isnt them
    Mar 2005
    01 Ebony - #0379
    Question
    How 'bout a dust flap in the wheel well catching on your tire treads?
    Good Luck.
    I don't I have dust flaps...
    Quote Originally Posted by Kenny
    Good Luck.
    2001 Ebony 0177
    you know, the plastic fender liners... but if that's not it, I'm thinkin' CV time. I'd be inclined to swap both entire axle assemblies, than do the CV's themselves. I don't know for sure on our car(have not had need) but it is the easy way out most times
    Well, I don't really have much to go on yet other than this sound. Driving the VX does not seem any different. No noises going forward, no vibrations, nothing.
    Quote Originally Posted by Chopper
    Arrow
    Bart,
    Have you checked your CV boots real close ?
    No sir, not yet. What should I be looking for? I have been underneath 3 or 4 times since returning from Moab, and I did not seen anything weird (leaks, etc).
    Bart,
    Arrow
    The conical rubber boots on either end of the half shaft (between the front third member & the hub (back side of where front wheel bolts on).
    Check them all around for tears/evidence of grease.
    If one had a tear, it might possibly make a popping noise as it rotates...that's about all that comes readily to mind.
    Good Luck.
    Turn up volume on stereo...no more noise...problem solved!
    Yeah, that's why I don't think I heard the noise until just last week. I usually have the Zen blasting through my stereo.
    Quote Originally Posted by Triathlete
    Aug 2006
    99, Silver, 1773
    Quote Originally Posted by nfpgasmask
    OK folks,
    Any ideas?
    Thanks - Bart
    Do you turn you head to look when you're backing? Chiropractor???
    Today I rolled around under my VX in search of anything abnormal looking and I found nothing. The CV boots look fine, no leaks or cracks. So, I am at a loss, but at the same time, not overly worried...
    CHECK THE BOLTS OF YOUR SUSPENSION!!!!!!!!!!
    These tend to come loose sometimes, and it makes a cluking noise when backing up!
    Thanks Dutchguy! But, could you be a little more specific with which bolts? I am just about worthless under there....so I need pictures or very accurate descriptions of where to look!
    Quote Originally Posted by thedutchguy
  1. Popping Noise in Front When Moving
    By bartmanS4 in forum Ldub's After Midnight Topics
    Last Post: 03/23/2015, 03:42 PM
  2. Clicking noise in dash
    By billh23 in forum VX Troubleshooting...
    Last Post: 11/07/2005, 09:47 PM
  3. Clicking noise?
    By Cyrk in forum VX Talk...
    Last Post: 03/24/2004, 09:08 AM
  4. SC owners... clicking noise from SC
    By Dallas4u in forum VX Modifications...
    Last Post: 01/14/2004, 07:28 PM
  5. Headlight seals popping out
    By cooks 7 in forum VX Troubleshooting...
    Last Post: 07/10/2003, 09:40 AM
