Just need a second opinion before buying a new alternator. For the past month, my VX will not start without jumping it. All electronics work, i.e. headlights, windows, radio. I had a mechanic connect a volt meter, and I believe he said the reading was 12 volts which is below the norm. The battery tested okay. This cannot be a bad starter, right? The starter clicks fast, then fades away. But like I said above, I can jump it. So it’s gotta be the alternator, right? Also, never replaced an alternator before, but it looks fairly easy. Can anyone tell me how many bolts are actually holding it on? I have the repair manual, but based on the diagram, I cannot tell if it’s 3 bolts or 6. THX
