Hi all... TOD started acting up about two weeks ago. Intermittently was dropping out of gear until I release gas, then reapply. Happens maybe 3 times a week. Also noticing sometimes klunky up shifting between lower gears.
So... took to local reputable transmission shop. They said fluid level was fine, but it was BLACK (burnt) which indicated major problems with the transmission. They said I needed to bring it to dealer for in-warranty repair or replacement (drive train warranty is 10 years).
So... I took it the nearest dealer last night (100 miles away).
Now, the dealer says It was just a leak, and fluid was low. They repaired the leak, and said I need to pick up the car. I argued the point repeating what the guy here said, but they said they drove it around and it was fine. I said it's an INTERMITTENT PROBLEM!!! I got them to agree to drive it another day, so maybe it's a moot point...
But this dealer is 100 miles away (the closest to my home) and having to drive back out there AGAIN later if fluid wasn't the problem is a big issue for me.
So... What do you all think? Could it really just be a fluid replacement and leak fix problem? Or are they just trying to get out of replacing an expensive transmission?
Thanks
-Mike
PS: the fluid has never been changed, and I've got 86,000 miles on the car. This was as per instructions from ISUZU. I asked them if I should ever change it, and they said it was a sealed system and all I needed to check every 20k was the level by removing the upper screw and seeing is fluid runs out. I did this maybe three times over the life of the car, and fluid level has been fine.
