Page 2 of 2 FirstFirst 1 2
Results 16 to 29 of 29
Thread: NEW Front Bearings and Disc install (pics) - oh what fun...
    '99 Astral #1977
    Quote Originally Posted by BlackVXer99 View Post
    Welp this was a fantastic write up.
    However im in my 10 hour right now, started around 8pm last night. Battled the following: 2 power outages from storms, 2 horsefly attacks prior to said storms, 3 stripped phillips screws, 1 stripped ABS ring screw, Many many overly-lock-tighted screws/bolts, broken rachets, back hurts, too many fumes, no sleep, need beer.
    But solid steady progress thanks to this write up. I was wayyy over due for new disks, pads, and fresh bearing grease. And will feel proud doing this big job myself
    Must ..finish.. ...
    I feel for ya! Good Luck!
    RichD
    I gotta do the front bearings now (failed inspection). Found these available for much less:
    http://www.wheelbearingwarehouse.com...+Seals&mode=PA
    Full set for both sides (including seals) with shipping came to less than $70.
    I'll let ya know how it turns out.
    Well, I decided to only do the passenger side with those bearings (inner came with outer race but outer didn't ... & they messed up the order & only sent 1 outer bearing. I'll get some quality bearings & do the full set soon.
    What I found was that the hub nut was very loose (I'm thinking the shop did not set the passenger side bearing pre-load when they changed out my half shafts). The 3 phillips head screws that everyone hates ... were stripped. I'm going to hit Fastenal on the way home to find some replacements & will post the part # once I get it right (hope to find them allen or torx instead of phillips).
    1997 Silver JDM 0623
    Please remember there is a shim behind the circlip to take the endplay out - i don't see it being replaced - so mostlikely its been lost ?
    it sits on the plate behind the circlip and is easily not seen - but its very important as it stops the driveshaft chattering - as yours seems to be very tight it may be ok - but of all the ones i have ever done on all the Isuzu's - i have never had a tight circlip like yours - except once ! - and that was from another owner having your problem - it turned out to be the outer race from the inner bearing not being seated tight in the hub
    regards
    Steve
    Isuzu Vehicross 3.2 V6 24 Valve
  1. Replies: 8
    Last Post: 12/18/2012, 10:01 PM
  2. Front Wheel Bearings
    Last Post: 06/02/2012, 06:51 PM
  3. Had my front bearings repacked today
    By Solitude in forum VX Talk...
    Last Post: 04/29/2008, 10:00 AM
  4. Repack Front Wheel Bearings
    By DK in forum VX Troubleshooting...
    Last Post: 03/06/2008, 02:20 PM
  5. Cost of repacking front bearings?
    By Dare2Dream in forum VX Talk...
    Last Post: 10/28/2005, 04:55 PM
