Results 1 to 14 of 14
Thread: Need Help with how to LIftthe rear end to install the 919's myself, thank you guys.
    2000 IronMan #11
    Man I just put a small block, like the size of VHS tape. so a 1x3 5-6 inches long. Yesterday I didnt even use a block of wood. Saftey wise just make sure your on level ground and I would not worry about anything. I got this lift method from a search where I think SPAZZ did this. Its just quicker and easier. Under the tank you will see 4 or 5 indentions the block of wood was just used to disperse the weight of the VX further than the 4inch disc of the jack. I hope you got a jack large enough.
    I ask her this weekend.
    whats wrong with lifting from the differential like the manual says to do?
    Jan 2007
    VX Skeleton owner
    Thanked: 6
    If you lift from the differential, the axle moves up when you jack, which compresses the springs which you are trying to take out. You pretty much have to use the gas tank method to do this, and I had to remove the rear shocks when I did mine so the springs and springjacks would fit in there. You may have to have someone push up on the opposite side of the axle that you are installing the spring on so that the axle pivots and lets you get the spring in. Don't forget that the bottom of the spring lines up against the metal nub on the axle.
    cool, makes sense, i for some reason thought that the diff would stay in the same place and the wheels would fall like normal
    Jan 2007
    VX Skeleton owner
    Thanked: 6
    In the front, since it is independent suspension, that would be the case, but since the rear is a solid axle, everything is one connected piece.
    Jan 2007
    *BHC* 1999 Ironman. :D 0454
    sweet, thanks you guys . Also, do u guys know how much lift i will gain with the 919's?
    Turning My VX Into Rally VX
    2000 IronMan #11
    Hum cant remember how much it is, but someone just recently posted the exact specs of them on another thread somewhere.
  1. Front and Rear Speaker install
    Last Post: 06/01/2024, 05:48 PM
  2. How to install rear seats?
    By Wantvegas in forum VX Troubleshooting...
    Last Post: 11/18/2014, 03:32 PM
  3. rear speaker install question
    Last Post: 03/05/2010, 11:00 AM
  4. need help to install the electric Fan please, thanks guys :).
    By CoastieCosta567 in forum General Tips...
    Last Post: 11/15/2008, 02:43 PM
  5. right rear panel re-install
    By ojmagg in forum VX Talk...
    Last Post: 09/22/2003, 06:31 AM
