Results 1 to 14 of 14
Thread: Need Help with how to LIftthe rear end to install the 919's myself, thank you guys.
    Jan 2007
    *BHC* 1999 Ironman. :D 0454
    Hi all. Well it's been 1 week and Rocky road have snet my the 919's springs and it will arrive this thursday, man they are coming faster then many have said. well anyways.
    How can I install the 919's My self?
    I was told I can do it, so i'll try but need the best safty help and help possible, thank you.
    Also has anybody every installed 919's and if so or not, how much lift will i gain with a VX thats "USED" By used I mean not New, wear on old stock springs.
    Also does 31" and 32 " tires mess with the TOD really bad, and if so How can I fix the Problem when it happends?
    Does 31" and 32" put stress on Stock suspensions, Cv joints, boots, stuff like that, or will stock do the job just fine?
    Thank you guys in advance, , can't wait to install, oh and by the way, i bought that GPS and man its BAD Ace, but i broke on the 2nd day, so they are sending me a new 1. I wish i would be hear to finish the DASH Mod, but till i return in 2 months I'll post the Pic's of the inside and show u guys the advancement. when i get the lift( with out tires yet) I'll post pic's and of extras done to MY VX. then when i return I'll show u the VX with tires. For those who don't know, I'll be going to BootCamp on Monday of next week. I'll post a Byebye Forum n Saturday afternoon. Man i'm gonna miss talking to u all and coming in here.
    Turning My VX Into Rally VX
    2000 IronMan #11
    For the lift question.
    Unbolt the shocks.
    Jack up the rear by placing a block of wood on the gas tank.
    Springs fall out
    Place the 919's in the same spot. (be sure to line up the bottom of the springs right in the axels seating for them)
    Lower the jack
    Re-tighten the shocks
    Your done in less than a half hour.
    Jan 2007
    Hey J, I new ur where gonna come and save me . What kind of block of wood, 2x4, I say this cuz of safty, like u know, i just got Married and I'm going to boot camp this coming monday, and i need to be in shape for myself and my Wife, I can't afford getting hurt. So whats the safty in this, 1 out of 10. thanks bro. Oh and by the way, so how the proposal coming, are u almost there?
    Jan 2007
    VX Skeleton owner
    Thanked: 6
    Those size tire have been used by many people for a long time now, but yes, they will place your CV joints under higher stress as well as the steering components. Some people have reported having to replace their CVs more often after lifting, while others have been fine with no troubles at all. Also, you will go slower off the line which kind of sucks.
    2000 IronMan #11
    Man I just put a small block, like the size of VHS tape. so a 1x3 5-6 inches long. Yesterday I didnt even use a block of wood. Saftey wise just make sure your on level ground and I would not worry about anything. I got this lift method from a search where I think SPAZZ did this. Its just quicker and easier. Under the tank you will see 4 or 5 indentions the block of wood was just used to disperse the weight of the VX further than the 4inch disc of the jack. I hope you got a jack large enough.
    I ask her this weekend.
    whats wrong with lifting from the differential like the manual says to do?
    Jan 2007
    VX Skeleton owner
    Thanked: 6
    If you lift from the differential, the axle moves up when you jack, which compresses the springs which you are trying to take out. You pretty much have to use the gas tank method to do this, and I had to remove the rear shocks when I did mine so the springs and springjacks would fit in there. You may have to have someone push up on the opposite side of the axle that you are installing the spring on so that the axle pivots and lets you get the spring in. Don't forget that the bottom of the spring lines up against the metal nub on the axle.
  1. Front and Rear Speaker install
    By LittleBeast in forum VX Modifications...
    Last Post: 06/01/2024, 05:48 PM
  2. How to install rear seats?
    By Wantvegas in forum VX Troubleshooting...
    Last Post: 11/18/2014, 03:32 PM
  3. rear speaker install question
    Last Post: 03/05/2010, 11:00 AM
  4. need help to install the electric Fan please, thanks guys :).
    By CoastieCosta567 in forum General Tips...
    Last Post: 11/15/2008, 02:43 PM
  5. right rear panel re-install
    By ojmagg in forum VX Talk...
    Last Post: 09/22/2003, 06:31 AM
