Results 1 to 15 of 17
Thread: Aggravation: Free of charge
    2001 Kaiser Silver #0664
    I've been having the worse time with my VX lately- too many mornings w/ a dead battery. Happened once while my daughter was driving it while we were away, so I figured she left the lights on or something. I've had it go dead after not driving it for the weekend, and noticing that I closed the door on the seat belt; not closed enough to turn off the dome light. I'm usually very careful about the belt thing, but after doing this a few times I decided to just pull the dome light bulb out. Last week, after left sitting for just a couple days- nothing. Dead as a road kill.
    I've taken it to a dealer to have the charging system checked. Alternator was fine. Everything was OK. They said there's a factory Izusu something that's drawing a small current- something about an anti-rust system, and offered to disconnect it, but I figured since it was all checking out OK I'd leave it be. It's got a brand new battery now, but something's not right. Cars aren't supposed to go dead if not driven for a week.
    Anyone with any ideas, I would appreciate it.
    Keith
    Thanked: 7
    Post
    Did they mean an anti-theft system? Is there any after-market devices that could possibly be shorting and draining your system?
    Anita
    2000 Ebony #263
    AnitaProtich.com
    Quote Originally Posted by Anita
    There's is an aftermarket alarm installed, so I thought that, too. Weird thing is, I've owned this VX for a year and a half with no problems, other than the occasional drained battery from my own doing, i.e. leaving the dome light on. So that's what leads me to think that it can't be that- it's been there all along.
    The dealer said there's an Isuzu factory anti-rust inhibitor thingie installed. It electrifies the frame and undercarriage to prevent rust- his words. And I may be wrong with the actual numbers/terms- but they said you want to be below 12 amps draw with an idle battery, and I'm at 11 amps. Disconnecting this anti-rust drops it to 5.
    I may take it back there and ask them to do it. I can't enjoy my VX if it's always dead in the garage, and my daughter will be driving it again this summer while she's home from school, so I can't have it dying on her all the time either.
    Jan 2007
    VX Skeleton owner
    Thanked: 6
    I'd like to know what this anti rust mechanism is since I'm fairly sure none of us on the forum here have ever heard of the thing. I have heard of the Navy using an electrified system on ships to inhibit rust, but never on a car.
    May 2002
    2000, Proton Yellow, VX, 0584
    The Anit-Rust mechanism is pure BS,, The steel body panels are galvanized to resist rust but, there is not a cathode that I'm aware of to keep the rust bugs at bay.
    Have someone you trust at a good quality parts store do a "Load Test" on your battery (Detached from the vehicle).
    Your problem sounds more like a shorted cell within the battery. Depending on the brand, most batteries have a sticker over the vent holes so your don't see them. (Usually between the posts) Does said sticker have a discoloration?? If it does, that is a tell tale sign of the battery "Venting", a common occurance when a cell is shorted (Caused by deposits stretching from one plate to the other). This venting is a release of hydrogen and sulfuric acid making the discoloration.
    The load test shows the defect much better than a simple voltage test. The load test will show the voltage of the battery under load (Which should drop dramatically over a short period of time) and be very different than a simple resting voltage test, which will most likely show 12 volts or just under making the service person tell you the battery is fine when it's not.
    Good luck
    Scott / moncha.com
    Quote Originally Posted by Moncha
    Wow, that's interesting. Thing is, it was a local repair place (one I trust) that told me about the rust-inhibitor thing- it was something they FOUND on the vehicle. So it wasn't an Isuzu dealer/salesman/parts guy saying it. Whatever it is, he said when they disconnect it the drain drops quite a bit. I'll report back when I learn any more- I've gotta do something to keep the thing from dying.
    The battery is two months old, so while it could be that, chances are something else is draining it.
    2001, Proton Yellow, #0580
    I'm with Scott on this one - my advice is get it checked and if you need a new battery, take a look at the Optima Red Top (or some equivalent spiral technology battery) - the peace-of-mind is well worth the extra cost (check Costco for the best price).
    -- John
  1. Replies: 2
    Last Post: 03/29/2015, 05:44 PM
  2. Free Rockrails
    By Rocky Road in forum VX Modifications...
    Last Post: 12/11/2006, 02:11 PM
  3. Free Free Free Free!!!!
    By biju in forum VX Talk...
    Last Post: 12/09/2006, 04:34 PM
  4. 2006 Dodge Charge Daytona
    By Cobrajet in forum VX Talk...
    Last Post: 06/14/2005, 09:13 AM
  5. ??looking to super charge???
    By 02RodeoS in forum VX Talk...
    Last Post: 04/29/2005, 05:10 AM
