Results 1 to 15 of 19
Thread: Whistleing engine...
    1999. Unique Ironman
    Hi gang!
    My engine whistling! I was driving today with oprn windowns and i notice that when im accelerating im hearing some kind of whistinh from under my car. It sounds kinda like cars with turbo sucking air that kinda sound like that. I tryed reving at idle and no sound only when im on gear and it start making that noise at 2000 RMP and higher, after 4000 RPM i cant hear it because sound engine gets louder. What it could be? Im thinking it mind be timing belt? my tranny currently leaking but i dont think it can make that noise and i have no idea what else it could be.
    thanks for answers
    Mar 2005
    01 Ebony - #0379
    Lightbulb
    Could be the elbow on the air box intake. It makes a noise when pulling in lots of air.
    I took mine off - made a deeper sounding intake - cool....
    Sep 2003
    `99 Astral #1889 (sold) | `95 Trooper TeraLows-5.38s-35s | `98 Acura SLX
    It might be your Intake Manifold Gaskets -- especially if you've also noticed any odd or irratic surging RPMs at idle.
    "This trail is so bumpy, it's knocking my bra straps off!" - Miss Kathy
    im going to check those things today after work and ill post it if it helped.
    Thanks guys
    Past Owner
    I just replaced my intake manifold gasket to remedy the same symptom. My whistle could be heard even at idle, but became louder as the RPMs increased. I hope your whistle is from something easier to fix. Good luck.
    Sep 2003
    Quote Originally Posted by TechnoPope
    Agreed.
    However, there is a 'Cheater's Trick' to doing the install that makes the job go a whole lot more quickly...
    Instead of actually removing the Intake, if you have an extra pair of hands around to help-out, it is *possible* to lift the Intake up off of the studs just enough to remove to old Gaskets and slide the new ones into place.
    Dec 2010
    1999/White/Ironman VX/0940
    I had a whining/whistling sound whenever I would put the gas pedal down more than 50% or when going up a hill and I took it into the shop and they found it was the EGR valve and a hole in the pipe going to the EGR valve.
    Problem with my whistle, is it is intermittent. Its not doing it today.
    '01 Ebony #0939
    Loose EGR tube nut? If it's backed all the way out, it could be intermittently seating itself then popping out again due to engine vibrations.
    Quote Originally Posted by Y33TREKker View Post
    I'll check it!!!!
    May 2011
    1999, black, VX, 0429
    you guys are awesome!! just bought mine and i was hoping that was not a normal sound!!! i will check on mine tonight as well!! thanks again!!
  1. '99 Vehicross Engine Knock / Engine Replacement Suggestions
    Last Post: 02/27/2012, 05:58 AM
  2. New engine!
    By Pepino in forum VX Modifications...
    Last Post: 01/17/2008, 03:00 PM
  3. Replies: 1
    Last Post: 06/19/2004, 04:36 AM
  4. Help Check Engine Blinking Engine Is Stuttering
    By Mr. I-MAN in forum VX Talk...
    Last Post: 03/15/2004, 10:02 PM
  5. Engine Oil
    By Andrey in forum VX Talk...
    Last Post: 05/25/2003, 05:23 AM
