Thanks for all the input. The problems have gotten progressivly worse and just last night the transmission was not shifting out of 1st gear and then it was slamming into the gears when it finally would after staying around redline for 5-6 secs. Then my check trans light started flashing on and off. Tried stopping engine and restarting nothing helped. Took it into dealer today and they said the fluid level was fine but it was throwing the auto transmission shifter lever code that VehiX mentioned, so they said $375 later and a new shifter lever I should be fine. We will see later today when I pick it up, I have my fingers crossed. Thanks again for all the input.
