I discconected mine and took it out on the drift pad at Morrosso, its fun but easy to spin on the street and low traction, kinda feels like ice (wet tar covered asfault). Im putting a switch on the shifter (easy acsess on the fly) and going to try it in the sugersand to see what happens. Im lookind to slide the back out in 2wd then kick the TOD back on comming out of the turns if I loose the float and re-engaging it when I need help getting back ontop of the sand and when starting. I do it with the E brake and have entered turns as fast as 60 in the sand but have problems with holding my speed ( E brake) Im pretty sure it will do well in RWD once you have your momentum sustained. I dont like the way it trys to pull you around above 35 or 40 MPH, specialy in sand rutts. In the snow or somthing with less traction id run with the TOD on always. Ow, did you now your VX tops out at 75 in the sand, im very impressed by that.
