Results 31 to 33 of 33
Thread: 8 hours in the garage yesterday...
Threaded View
    ...and here is what I did:
    1) I bought the Coleman Safari Rack (thanks for the tip, Etlsport!). However, with our stock Yakima rack, the mount points didn't quite line up with the Coleman rack, so I had to shorten the tubes by 3/4 of an inch. Now it fits perfectly, and was a h3ll of a lot cheaper than the Yakima or Thule basket.
    2) Finished installing Tone's frame mounted hitch receiver and wiring harness. What a BEOTCH, but it looks sweet! Thanks Tone!
    3) Bought a ScanGuage II from Tone also, and embedded it below the lower DIN slot. It looks REALLY good sunk in here, and fits totally solid. I cut the rectangular slot out with my Dremel, making the project pretty easy. But, the Dremel left the opening a little rough around the edges. I took some black rubber tubing I found at Home Depot in the plumbing section and split it down the side to make a little "frame" for the top, if you will. But I am not to happy with that either. Do any of you have any ideas for an actual frame or some sort of trim that would work here? I want to finish it off nice and make it look more stock.
    I also made some time this lazy Sunday morning to update my VX Madness site, so check the pics and mods sections for some new stuff.
    Thanks,
  1. Hours of quality entertainment!
    Last Post: 11/12/2010, 10:42 PM
  2. 8 hours to replace window seals?
    By ctp in forum VX Troubleshooting...
    Last Post: 03/11/2009, 08:07 PM
  3. Will these Wheels fit?? Only 3 hours left on auction!! Help!
    By crotchrocket in forum VX Troubleshooting...
    Last Post: 01/24/2009, 01:57 AM
  4. 4 hours and counting...........
    By 9tinyfingaz in forum VX Talk...
    Last Post: 06/10/2006, 07:24 AM
  5. Flight hours....
    By Francesco Rizzo in forum VX Talk...
    Last Post: 12/20/2004, 07:56 PM
