Results 16 to 17 of 17
Thread: A visit to Mod heaven
Threaded View
    Jan 2007
    VX Skeleton owner
    Thanked: 6
    Talking A visit to Mod heaven
    So, the VX has been down for several weeks while I tore out the front end to get at the differential drop brackets to lift it. Long story short, a lot got done to the VX, like:
    2" extended diff drop brackets
    1.5" drop brackets for forward frame cross-member(under forward driveshaft)
    New inner bearings and seals
    Mecatech CV boots
    Brand new upper and lower ball joints
    Ball joint flip
    Independent4x brake lines
    Brake caliper speed bleeders
    Energy suspension polyurethane low profile bump stops
    Energy suspension polyurethane tie rod dust boots
    Custom made 1 1/4" Powder coated 4340 Hex tie rods w/grease-able rod ends
    Energy suspension grease-able sway-bar bushings
    Re-indexed front suspension to 4" of lift
    Installed Nitrided steel spring jacks in the rear for 4" of lift
    Energy suspension polyurethane coil spring isolators
    4 Mega 835 20" rims
    4 Nitto 285 55 R20 Nitto Dune Grapplers
    Aisin Locking front hubs
    Brakes flushed and filled with ATE Super blue brake fluid
    Front and rear differentials changes to Mobil 1 full synthetic
    Oil changed to Mobil 1 synthetic
    All bearings/bushings lubed with Red Line CV-2 synthetic grease
    All brake parts and ball joints painted with Hi-temp red ceramic paint
    Here's some pics, Sorry about the bad lighting, but it's overcast outside. The guys at the alignment shop said their machine can't hook up to that rim size with the Nittos because the bead is too tight. So tomorrow, I get to take these of, put the old ones back, have it aligned, then put these back on. So far though the ride is nice and smooth. I love being up high, and man, I thought people looked before, but now I think I might cause an accident or two.
  1. HP HEAVEN - exp with modding our engine
    Last Post: 08/23/2012, 05:53 AM
  2. 30k dealer visit!!
    By jamessmith in forum VX Troubleshooting...
    Last Post: 08/02/2007, 09:30 AM
  3. Visit to CarbonFiberOne - LA VX'ers
    By Anita in forum VX Talk...
    Last Post: 07/15/2005, 10:13 PM
  4. UK Visit 12/17
    By Bantan in forum Meets...
    Last Post: 02/22/2004, 11:05 PM
  5. Carmax Visit
    By Jonnie in forum VX Talk...
    Last Post: 07/24/2003, 05:56 PM
