Any input on some q's would be greatly appreciated.
Wind/Rain Deflectors
I have seen photos of a particular deflector that I think may be the OEM version (http://wildtoys.com/vehicross/VX_Mod...ctors_600.jpg). I am having an extremely hard time finding a pair. Does anyone know where I can find some? I am aware of the WeatherTechs but have not seen a photo of them installed on a VX. Does anyone have a pic of weathertechs on a VX?
Moonroof/Glass Roof
I've seen a few moonroofs that look great but wanted to know if anyone has installed a glass roof (or a section of it). For example, instead of a basic square-shaped moonroof, installing a long skylight that would start where a moonroof normally starts but ends up over the back seats.
Pedal Cover Set, Shift Knobs Replacement
I was looking at the new Momo Atomik set (http://www.ekmpowershop4.com/ekmps/s...productid=134). I think the E-brake cover and shift knob (for 4x4) will work however am not sure if I can use these pedals. They are for manual transmission and am not sure if they could be retrofitted to work. If not then I will still use the E-brake cover and shift knob but use another Momo set for pedals (http://www.eautoworks.com/html/ORD-1-1-1-6998.cfm). Does anyone know if the manual pedals would work or would I have to use the automatic version? By the way I'm thinking of these new floor plates to match (http://www.ltbmotorsports.com/mogrt2flma.html). Since I have a proton I think this new Atomik set will look pretty good.
Dash Mod
This mod looks great (http://www.vehicross.info/forums/sho...ight=dash+mod). Has anyone else tried it or something similar? Can the colors of the AC knobs/buttons also be changed or am I stuck with green?
CF Stuff
I have PM'd and emailed Dutchie about any CF accessories he still has available such as the CF Door Skuff Plates, CF Half Moon (for tailgate/rear door), CF brake light covers and a CF Hood Insert (if it is even available). I haven't hard back yet but wanted to know if anyone has any of these or other items like them? Are they good quality and problem/troublefree? They look great although a bit pricey...
Onboard Computer with Touch Screen
By the way, I found this article that I think some may find interesting. It is a simplified version of what others have done. I will go this route however instead of mounting the LCD I will install it in the dash.
http://www.popsci.com/popsci/how20/d...cbccdrcrd.html
Thanks for any input![]()
