Any suggestions to look jout for for a service I have on Monday. I will be having the following service done:
Tranny Filter and Fluid Change-I am supplying fluid, filter and gasket
TOD Flush and Fluid change- I am supplying fluid
Radiator Flush and Fluid change, thay will provide fluid or any reco fjor hot FL weather better that Isuzu stuff?
Brake Inspect and Front Bearing Inspect and repack if needed
35K on my o1 I switched Diffs and engine oil myself to Mobil 1, new air filter, EGR Valve and will go Mobil ! with above services.
