Results 1 to 15 of 29
Thread: OMG My Gas Mileage!!! General Question Need Everyones Help
    Oct 2005
    2001 Proton Vehicross
    My vehicross has a pretty much stock exhaust and engine with a powergem intake(just a step up from stock nothing major yet) i only get about 225 mileage on a whole tank of gas. basically 10 miles to the gal. Its killing me. anyone have any tips on how to get this up so i get more mpg i see other vx owners getting 300 up to 450 how the heck is that possible any and all help much appreciated or it might go up for sale. Thanks
    2000 IronMan #11
    Do a search on here.
    Oct 2006
    2000, Green, Vehicross, 0054
    No worries Lizardmen, I'm not that much better and I have ZERO power mods to the VX. I get basically 16-17 mpg, if I get 18 I'm thrilled. I have no dreams of getting 20 or above. I don't know how some of these other guys do it. Yes, I use constant throttle pressure, very limited brake action, always in 4th when I can help it, rarely goose it around traffic and my mileage still stinks. Oh well, I knew gas mileage was one of the faults with the VX. At least we get to use regular gas!
    The only thing I can think of in your case is to make sure the tire pressures are good, if one is really bad or more than one are kind of bad, that would be a cheap and quick fix to your problem. Especially given the large size of these tires. Good luck!
    Smile Hmmm...
    I get about 400 miles per tank. I change the oil every 3k and I only use Cheveron 91 octane. every other brand makes my engine sound funny. But that is about all I do. Mine is totally stock. all my mods are on the inside. Oh I keep it really clean too...so that might help with gas mileage...lol...
    Oct 2005
    u get 16-17 i barely get 10 my pressure is right on at all times my tires r 285 60 r18. i havent a clue. i no it can get better maybe ill add a new duel exhaust and better intake any one have duel exhaust that is happy with wut kind should i get. i also change oil every 3k i use hile mileage and synthectic and all that good stuff.
    2000 IronMan #11
    seafoam gas tank, oil, through pcv. check spark plugs, o2 sensors, injectors. Clean egr, throttle body. Change fuel filter, drain a little from the bottom of your gas tank.
    2001,FOX FIRE RED MICA,0251
    Check your brakes maybe they are not releasing completely,check egr valve it could need to be cleaned or replaced and check your intake gaskets.Just had my intake gaskets replaced and all my problems went away,bad mileage,bad idol,exaust smelled rich.
    1999 Alpine White Ironman 1970
    i think the 18" vs 16" wheels have a lot to do with it. i bet most of the guys with the higher mileage are running 16's with stock tire size.
    your 285 60 18's (i run the same size) are heavier than the stock 245 60 16's AND considerably taller. remember the profile number (60) is not a direct measurement, it's a ratio that depends on the width.
    i think the speedo is off by 6% with my terra grapplers of the same size. and most of the extra weight is now located further from the center of the wheel, which requires much more enegy to rotate.
    Aug 2003
    1999,Silver,Vehicross,0928
    16mpg combined on stock 16s with a pv muffler.....
    99 Astral Silver 0644
    New, 21mpg with everything stock. Now, 19mpg with K&N air filter, Bridgestone AT Revo 265/70SR16 tires and Mobil1 oil, changed every 3000 miles. Everything else on the engine/transmission is still stock.
    Oct 2005
    so bigger my rims and tires are less gas im gonna get as well cause i wass gonna get some bigger rims soon? i had a complete maintence done to it few months back so i think all that stuff is good but about stuff to put on a car to make mileage better is that tornado any good or the bosch plus 4 spark plugs and minor stuff??
    2001, Proton Yellow, #0580
    A short answer on those gizmos - don't bother, they don't work.
    Some engines just aren't as efficient as others - plus environmental factors and general engine wear and tear all contribute to gas consumption. I usually get around 12-13 MPG on my VX in the city - it goes up to about 16-17 on interstate driving trips. The more performance mods you have, the worse this gets - mostly because the mods introduce higher airflow or more fuel boost - this creates better response times and usually causes the driver to drive more aggressively - it all contributes to poor gas mileage. Remember the VX weighs in excessive of 2 tons with a driver - the full ladder frame and full-time 4wheel drivetrain all has its toll on engine efficiency. If you're looking for a gas saver, buy a motorcycle and swap off driving every other day - the VX just isn't a good candidate for economy gas mileage.
    -- John
    Dec 2004
    A while back someone was complaining about getting very low mileage, but they were not calculating their mileage correctly. That person was filling up, driving until the needle is on E, then filling up again and dividing the 22 gal tank capacity (instead of how much gas they actually put it) by the miles on the trip odometer. This led to an overly low mileage estimate. Properly done, you should fill your tank until the pump shuts off, reset your odo, drive it to empty, fill it until the pump shuts off again, then divide the miles driven by the actual number of gallons you just put in.
    Now, I'm not trying to say that you must be doing the math wrong, but 10 mpg is unusually low, so I suspect something is fishy in the calculation.
    I seem to average about 14-16 mpg... low in the winter and high in the summer. The new tires I put on last year robbed me of about .75 mpg. My Yakima cargo box or ski rack lowers my mileage another 1 mpg or so. Bigger tires and wheels are heavier tires and wheels which take more power to spin, so that will reduce mileage too.
    '99 Ebony VX #0038
    Right, what VehiGAZ said - and most importantly, understand what iamjacksadrenalgland mentioned about having larger than stock tires - even if you are doing perfect calculations, your data is inaccurate because larger tires throw off your speedo/odo, so it may appear that you are getting much worse mileage than you actually are.
    I've got 33" tires on 16" wheels, and I estimate that my speedo/odo are off by about 10%. Adjusting for that difference, I probably get 12-15 MPG on average.
    I just ordered Tone's scan guage. I have never used a scan guage before so now I am wondering if it will give me accurate MPG calculations....we shall see. I'm really bad at math so I could use the help....
    All I know is that when I get on the open road and drive for 2 hours at 85-95 MPH my VX CHUGS gas.
  1. tire sizing question-general
    By blujfan9293 in forum VX Talk...
    Last Post: 11/08/2010, 09:18 PM
  2. General VX question
    By rjbuiso in forum VX Talk...
    Last Post: 07/31/2009, 02:14 AM
  3. General question
    Last Post: 01/08/2009, 07:53 PM
  4. general wheel question
    Last Post: 06/25/2008, 05:52 PM
  5. Everyones going to want one of these...
    Last Post: 10/21/2005, 08:47 AM
