Results 1 to 7 of 7
Thread: Check Engine P0440
    Check Engine P0440
    Will my problems never cease?
    Anyway... my check engine light came on again after cleaning the mass air sensor.
    I got an OBD II computer (neighbor had one, go figure) and checked the code. It was a P0440... which is an EVAP system problem.
    My question is ... how/what could have happened and how do I fix it?
    I cleared the code, and filled up with gas in case I had a bad tank. So far, no check engine light, but I'm expecting it to come back on soon...
    Any ideas would be appreciated.
    I am having the same problem. It started a few weeks ago, I called a dealer and they told me that I most likely didn't tighten the gas cap hard enough. I always do, but I said ok. I reset the code and filled up again. Everything was fine for a few days. Then it came back again. I did the same thing, and again it was fine for a few days but then came on again. For now, I am just ignoring it since everything seems to work fine, but I will give dealer a call sometimes soon.
    Please let me know if you find out what's up!
    Yea, the dealer tried to tell me the same thing... which I knew was BS.
    So I'm still waiting for it to come on again... not sure what I'm gonna do at that point.
    Here is what we can do: take some duck tape, tape over the check engine light and BAM - no more annoying light :-)
    Seriously though... I am getting a little nervous since it could be something serious and I don't know about it.
    2001, Proton Yellow, #0580
    Shortly after my 30k maintenance, I started getting what I believe was the same code (I don't remember and didn't write it down). Took it in and they upgraded a software fix (sounds like a firmware upgrade), which cleared the check engine light. I was told it was a software glitch and not an actual problem. You may want to check into this.
    -- John
    May 2003
    2001, yellow, 1329
    i had the same problem w/ the check engine light. i took it in and the dealer service dept told me the same thing, that my gas cap was loose and they wanted $85.00 to turn it off! i always tighten my gas cap but thougth hey maybe i didnt last time....they said make sure your hear 3 clicks when you put the cap on.....i too am waiting for the light to come on again.....
    stan
    May 2003
    2000 Ebony VX 0577
    Mine too.. It is always on. Same code. But I think it is from when I got my body lift put on they have to extend the filler tube with a rubber hose extension. Maybe not the best seal?
    I always take life with a grain of salt. Plus mashed potatoes and gravy!
  1. CHECK ENGINE light - code P0440
    By Yefim in forum VX Troubleshooting...
    Last Post: 03/07/2013, 05:54 PM
  2. Check engine
    By Knivx in forum VX Troubleshooting...
    Last Post: 08/09/2008, 08:01 AM
  3. Check Engine - Off/on/off/on what..
    By Corrosive in forum VX Troubleshooting...
    Last Post: 11/22/2006, 04:12 PM
  4. Help Check Engine Blinking Engine Is Stuttering
    By Mr. I-MAN in forum VX Talk...
    Last Post: 03/15/2004, 11:02 PM
  5. Check Engine
    By Eckstream in forum VX Troubleshooting...
    Last Post: 10/02/2003, 09:22 AM
