Results 1 to 5 of 5
Thread: clonking noise
    Sep 2006
    1997silverjapaneese1254
    clonking noise
    viewed lots off other links to this problem but cannot find any usefull information it clonkes when changing from d to r and also excelarating and de excelarating it only started this about a 600miles ago i have about 80k on clock the reer dive shaft has no play in it but have noticed some movement were the drive shaft comes out of the geerbox is their a bearing gone their has been a bit of a wine noise since i was doing donuts on the beech the other month back dif oil level is good running a arb aswell but dont think this is the problem no oil leaking at drive shaft outlet and level off oil in geerbox is ok and i do the greese nipples every other month. any info please
    How long has it been since you changed your trans fluid and filter? I would check that out...
    i would get a loud clunk after hard braking, i changed my transmission fluid and both differentials (mobil 1 synthetic in the differentials, valvoline atf in the trans) and all the clunking has gone away, and i have less whine than i used to
    2001,FOX FIRE RED MICA,0251
    Yup!trans fluid and filter change should do it,it fixed my cluncking.
    Sep 2006
    found out wot it was
    the pasenger side rock slider i installed 2 months ago had bent up and rubbing the sill under neath when shifted from d to r .i had bolted the rock slider to the mount of the rear swinging arm just bent it down by jumping on it no noise now
  1. Noise from below
    Last Post: 09/14/2012, 05:48 PM
  2. New noise.
    By crager34 in forum VX Troubleshooting...
    Last Post: 08/03/2011, 12:53 AM
  3. What's that noise?
    By edwin in forum VX Troubleshooting...
    Last Post: 09/11/2006, 09:41 AM
  4. TOD & low 4wd noise!!!
    By anut in forum Japanese Domestic Model (JDM) VXs
    Last Post: 06/14/2006, 12:44 PM
  5. Odd Noise - TOD ?
    By t2p in forum VX Talk...
    Last Post: 07/06/2004, 09:29 AM
