Page 2 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 16 to 30 of 78
Thread: timing belt jumped
  1. #16
    2000, Black VX #0754
    How was it that you noticed the timing belt jumped? Was the engine running funny? I'm assumming, that if it jumped that it through the timing out of sync?
    Also I'm glad that they are covering it for you. When I had my Jeep Wrangler the company that I had wouldn't repair anything. Everything fell into the loop hole called "Wear Items" which was not covered.
  2. #17
    '99 Ebony VX #0038
    IndianaVX - I concur with Merlin, I think it was more than likely a worn tensioner that allowed the belt to skip in the first place, so you should most definitely replace it. However, if you're going to take everything apart, you might as well replace the belt (and possibly the water pump also). I personally did NOT replace my water pump because I couldn't really spare the extra $150 at the time, but normally I prefer to err on the side of caution. Either way, replace the belt and tensioner and you're good to go for another 75-100k miles. Replace only the tensioner and you'll just have to tear it down again in 36k miles.
    A word of warning - Mark is 100% correct about NOT rotating the cam shafts once the belt has been removed. Much of the published information is incorrect, and if you follow the CD manual letter for letter, you'll screw up your timing and the cam shafts will need to be reindexed. I know because I made that mistake myself and wound up having to have a shop complete the job for me. There is a TSB that explains the issues, and the correct way to reindex your cam shafts. The shop that does the work should have access to this TSB, but I also have a copy somewhere. If you need it I'll dig it up for you (please PM me). In all likelihood they will need to do this reindexing, since your belt skipped and the timing is probably off now.
    FWIW, I also concur with Tone - I am under the understanding that this motor is, in fact, NON-INTERFERENCE.
  3. #18
    kpaske,
    If you do find the TSB on cam timing, how about forwarding it to Moncha to add to the download section.
    That right there could be some handy information to have.
  4. #19
    Apr 2006
    2007 Suzuki V-Strom 650
    Weird. I totally had my cams & stuff all out of whack and I don't remember having any particular trouble getting it all lined up. It was mostly a pain in the butt because the cams wanted to snap out of place due to valve spring pressure.
    I followed the CD manual's procedure. Maybe I got lucky?
  5. #20
    1999, Ebony Black, VX ,1976
    Quote Originally Posted by JAFO
    The ignition timing would not be off. But the cam timing would be. shawn
    1COOLVX
  6. #21
    '99 Ebony VX #0038
    Quote Originally Posted by Tobert
    You must have. I did the job TWICE myself, using the CD manual, to the letter, and my timing was all screwed up. I took it to a nearby shop, and it took them THREE tries before finding that TSB and correcting the problem.
    I'll try to find that TSB and get it posted here. It's a little oily, but it should scan OK to be readable.
  7. #22
    Apr 2006
    Arrow
    I've been trying to remember what I did to get it right. I am not a professional mechanic, so don't be afraid to correct me ...
    * check #1 TDC on the crank by probing the #1 cylinder with a long screwdriver (don't rotate the engine with the screwdriver in the spark plug hole as you risk gouging or worse, breaking pieces off in your cylinder chamber -- it's probably safe if rotating with a wrench, but don't blame me if something goes wrong)
    * work with the valve covers off so you can see which valves are open
    * use only a wrench to rotate the engine to protect your parts and yourself
    * take your time and wrap your brain around the process of how the cams and crank are synchronized, then it'll become clear how it should be
    With that information, it's pretty easy to figure out if you're on the right revolutions from there. For example, you know when you're on #1 compression stroke when both valves are closed and you're at TDC. Then you can forward through the firing order and figure out where everything else should be when the cams and crank are set at the default marks.
    Once you put the belt on, rotate it around a bunch of times by hand and follow the firing process in your head. If the firing order is 123456 (I don't think that's right for the VX), you should see compression stroke on #1 with both valves closed, then the same on #2 and so on ... simultaneously, the next upstroke on #1 should be exhaust ... you get it.
    Save yourself some time and go buy a few of those metal office clips suggested in the service manual. They really help a TON. It would probably also be a lot easier with two people, but I did it myself.
    When I put a new timing belt on my wife's Subaru, I actually started it up while the timing cover was still off to make sure I got it right. Don't run it more than a second or two as the engine will burn up without coolant around the cylinders and in the heads. The temperature gauge is useless without coolant, so don't rely on it
  8. #23
    Mar 2006
    2001 FOXFIRE 0579
    Okay,
    heres the update.
    My mechanic put a new timing belt on today. said the vx ran like new!!!!! it ran so well, that he didnt even feel that its necissary to do a compression check.
    so i called merlin, ordered a water pump, and a belt tensioner rod. im going ahead and paying for these parts for peace of mind. so i should have my truck by middle of next week!!! I CANT WAIT!
    this brings up a couple of things to my mind though. did i just get lucky that the valves didnt kiss the pistons in this interferance engine? or is this a sign that it is a non interferance? who knows, and at this point, i dont really care, im getting my truck back!!!
    cant wait to shine er up, and smile again.
    david
  9. #24
    Aug 2003
    2001,White,Rodeo Sport,
    The engine is a non-interference engine, you'll be fine.
  10. #25
    excellent news.
    -biju.
  11. #26
    Mar 2006
    2001 FOXFIRE 0579
    Hey people....
    anybody got a copy of the TSB that kpaske was talking about?? looks like im needing it. got things together, new pump, and tensioner rod, put back together, and it runs like crap. im taking a copy of the post on page 2 for the tech training. hopefully that will help, but the tsb would be great. or if someone has the number, i can tell my mechanic to look it up, wherever they look that stuff up......
    as always, all your help is appreciated!!
    Thanks
    david
  12. #27
    Mar 2006
    2001 FOXFIRE 0579
    ok, i cant copy and paste the post that deermagnet made on page 2. anyone got a copy, or tell me how to copy this so i can print it out for my mechanic in the morning??
    thanks again
    david
  13. #28
    Thanked: 7
    Quote Originally Posted by IndianaVX
    thanks again
    david
    David,
    Its a number of picture files so all you need to do is a right-click on each page and save it to your computer. Open up each photo with a picture/photo software and print them off.
    Anita
    2000 Ebony #263
    AnitaProtich.com
  14. #29
    Mar 2006
    2001 FOXFIRE 0579
    anita, mark,
    thanks, as always you all are so helpful........
    thanks again.
    david
  15. #30
    Mar 2006
    2001 FOXFIRE 0579
    ok, i am at a loss of words.
    Ive got a good mechanic working on the vx, he really is. has worked on my stuff for over 10 years.
    BUT, hes having a heck of a time with the timing issue. I have given him the post from here. he has the same service bullitins. lines everything up proper, and then it wont start, or runs poorly.
    He is complaining that what isuzu has printed is wrong(which ive read here too) and thinks that the problem is in the translation. he mentioned that he has the same problem with hondas, and other foreign makes.
    hes done compression check, leak down, passed well within specs.
    IM REALLY NEEDING SOME HELP.
    it seems everyone has had this same problem. i have searched the threads, given him everything i have printed out on others attempts. (man, im getting a headache)
    is there anything you all can think of that i can relay back to him that he might be missing? is it that easy to be out 180 degrees? he has oem belt.
    if the cams WERE turned individually, and things got out of whack, man, im typing out loud, and cant even finish a thought.
    am i correct in saying that the procedure on tones cd is wrong also? (no fault of tones)
    I was joking about taking the shilloette to badlands, but im thinking i better call oldsmobile, and get that 3" lift and some terra grapplers for it.
    Im sorry guys to have to ask, but can you scratch you heads a little more for me, and come up with some suggestions?
    its gotta be just one of those small things that are head bangers, then, BAM the light comes on.
    sorry to ramble so long
    i gotta get an asprin or two..........
    thank you all, really, thank you!!
    david
  1. Did I screw up my timing? Timing belt replacement
    By workmeistr in forum VX Troubleshooting...
    Last Post: 04/13/2015, 08:26 AM
  2. Timing Belt......
    Last Post: 11/03/2009, 06:39 AM
  3. Timing belt replacement and timing videos
    By deermagnet in forum General Tips...
    Last Post: 11/26/2007, 09:09 PM
  4. Timing belt replacement and timing videos
    By deermagnet in forum Archives
  5. Timing Belt
    By Randy in forum VX Talk...
    Last Post: 10/21/2003, 10:42 PM
