Yeah, I agree with Ascinder, it could be a bad connection somewhere if there is an intermittent failure. I would just remove the side panel to look around. Perhaps the motor was replaced before and something went together less than perfectly. Check your motor, and if the brushes are burned up then you will need to replace something. If the motor is fine then you most likely do have a bad connection.
