O Kayyy... that's helpful, never heard that one before. James, there are several threads on here about this common problem. Do a search and you will be well informed on how typical this problem is and what people have done to fix it... or how to put a bandaid on it anyway. You will most likely have to replace your window regulator motor unless you can find some replacement brushes for it, which I am hoping to find sometime. Replacing the motor is simple but replacing the brushes on your existing motor would be much cheaper and just as easy if you can find some.
