Quick History: My Fuel Injectors were sucking air around them and I moved the fuel rail to get the noise to stop, but I agree with you guys that I should just replace the o-rings (I still get a LEAN CODE once in a while).
So I have the new O-Rings (14 in the package - 7large & 7smaller - must be 2 spares) and hope to replace them in the next couple weeks (weather permitting). It looks fairly easy... Couple hours if I take my time?
Here's what I think I need to do (based on last look a couple weeks ago), so correct me if you see something I missed or a link that already talks about it (I didn't find any).
1) Pull fuel pump relay and run engine to bleed off pressure.
2) Unbolt fuel rail
3) Looks like you have to pull out a clip on each injector to detach from the rail (Is there an o-ring up there also or do both go down in the intake manifold???)
4) Pull out injector and find o-rings and replace'em
5) put it all back together
6) Dance a Jig if it runs better!
Help - Hints - Tips - Am I close????
Thanks in advance
