I noticed recently that I was only getting sound out of the rear speakers, I moved the fader and not much at all was being heard out of the fronts. I realize that just replacing the speakers MAY not be the actual culprit, but I want to do it anyway.
Here's the question, never replaced tweeters before, are they basically interchangeable? The stock wiring looks pretty slick and I want to avoid as much wiring as possible.
Also, the rears look pretty standard but the plastic connector on the speaker looks a little more complex than what I'm used to in past cars. When I've replaced them before it was basically attaching the separate female wires to the males and end of story.
Sooo, seeing as how I want to do as little modifying as possible, does anyone know what speakers will hook up to the front stock wiring system with no alterations?
THANKS!!
