Results 1 to 15 of 41
Thread: engine tapping ...oh no
    '01 Ebony #0939
    Quote Originally Posted by Tobert
    It could be valve adjustment. Mine taps like crazy, especially on lighter weight oils.
    I was just throwing out ideas with the electrical snapping idea. I guess I had just assumed that the 3.5L VX motor used hydraulic lifters, but I see from the cd manual that a solid lifter bucket/shim type adjustment is used, so valve adjustment could very well be the cause.
    How many miles on the engine? VX valve adjustment intervals are every 60k miles.
    Mar 2006
    2001 FOXFIRE 0579
    just rolled 63000..........
    Check your exhaust system to find the most likely cause of the sheet metal rattling sound...the heat shield(s) are a known culprit.
    Nov 2002
    Arrow
    If you have a Harbor Freight nearby you can pick up a mechanic's stethoscope for about $6 which can help isolate the source of the sound. You can also find them at NAPA and other auto parts houses for a little more.
    If the sound is coming from the head then it's likely the hydraulic valve-lash adjusters, which have a published known-issue of sticking from varnish build-up. The typical "fix" is the use of 0W-30 or 5W-30 Mobil-1 which will remove the varnish over a period of time. The adjuster could also be failing (unlikely at your mileage, but possible), which in a worst-case scenario would cause very rough running as the affected valve stuck open.
    Ldub's exhaust shield clatter is another valid possibility, and a while back Johnnyapollo had a noise that would only happen while in drive that turned out to be the exhaust making contact with the right side suspension link.
    How long have you had your VX and been using Mobil-1?
    1999, Ebony Black, VX ,1976
    Quote Originally Posted by Joe_Black
    What??? The only way to adjust the valve is with a type of shim that goes on top of the valve stem. We call them lash caps at work. We do not have lifters on the vx. It is a setup were the cam opens the valves. shawn
    1COOLVX
    Nov 2002
    Arrow
    I know, that's what I thought at first since that's what I'm familiar with as well from my FIAT/Lancia and Kawasaki DOHC experience. Apparently, and this is according to Isuzu service information and not my actual under-hood experience, our engine has hydraulic self-adjusting "lash caps". I'm about to have lunch with a friend who owns and operates a local major repair shop and will have more info then.
    UPDATE: Apparently there is a such thing as a self-adjusting hydraulic tappet bucket for direct-impinging OHC and DOHC applications. When home later I'll look in the service manual for more info.
    Mar 2006
    2001 FOXFIRE 0579
    thanks guys
    yes, i am suspicious of the exhaust rattle, not real concerned about it, but it will be found and dealt with....
    Joe, i have owned the vx for a year, and changed to mobil 1 2 days after i got it. so its been running mobil 1 for a year. i also run the lucas syn oil stabilizer. and run the lucas gas additive...(forget the name) for cleaning the top end.
    there is no noticable power loss, i cant make the tapping. it just happens. have heard it once today.
    thanks again guys for the intrest, and input.....its appreciated
    lunch is over... gotta get back at it!
    david
    I have looked in the manual and I am finding nothing about this. It looks to me that this is not the case and they are not self adjusting. But I am not 100% positive. If they were self adjusting hydralic there would be no valve noise. You can notice a big difference between hydraulic and and solid lifters, I would think that this would be the same. shawn
  2. tapping on bottom passenger side/ help please.
    By CoastieCosta567 in forum VX Troubleshooting...
    Last Post: 03/23/2007, 07:59 AM
  3. Engine Tapping
    By Otto in forum VX Troubleshooting...
    Last Post: 01/30/2007, 04:00 PM
  4. Replies: 1
