A HUGE THANK YOU TO COWBOYERIK!!!!!!!!!!
I've been in a VX depression ever since I heard that darned knocking sound in the motor. I even warned my wife about the "potential" of the motor going kaput long ago. After reading CowboyErik's post, I felt I had hope still. Sure enough! I pulled off the passenger side timing belt cover enough to push on the belt. Without any trouble at all I was able to deflect it by almost an INCH! So, after about 45 minutes I had the front end torn apart and found that the timing belt tensioner went bad!!! I can plunge the piston with my hands with ease, and there is oil leakage around the "pushrod" base. (see pics).
SO, IF YOU THINK YOU HAVE ROD KNOCK/ENGINE FAILURE, CHECK THIS BEFORE SENTENCING YOUR VX MOTOR TO DEATH!!!!
