Results 1 to 4 of 4
Thread: mirror heater switch
    2001, Dragon Green, 1342
    Awhile back, I read here that someone had moved the mirror heater switch from the center console to the dash. If your reading this, was there enough wire in the loom or did you cut and splice?
    theres a connector under the e-brake that lets you disconnect the mirror heater and mirror adjuster, so theres only actually like a foot of wire there, i had to cut and splice, not too hard a job... i think its 5 wires
    yea, 10-4, been apart before, just didn't know if the loom came down from the firewall. Splicing is no problem. Do you remember what gauge off hand just so I can have it on hand
    i used 18ga speaker wire, that way i only had to run 3 (2-1/2) wires.. my advice would be get inline connectors... i have strange angles in my wires because i used connectors like wire nuts that you crimp (dont know what theyre called but you use them for head units) anyway it makes it a little more difficult to get the wire in place.. all in all its a fairly easy process
    id also reccomend installing quick disconnect connectors for your alarm LED while youre in there.. makes takin the dash off easier now and in the future
  1. Wiring diagram for folding mirror switch
    By Mile High VX in forum JDM Parts & Accessories
    Last Post: 10/06/2016, 08:26 PM
  2. Mode Selector Switch & Power Switch
    By ahdoman in forum VX Troubleshooting...
    Last Post: 11/20/2014, 11:34 PM
  3. Power Mirror switch and Defogger NOT working
    By VX-Man in forum VX Talk...
    Last Post: 03/06/2013, 03:11 AM
  4. Heater/AC
    By texasvx in forum VX Troubleshooting...
    Last Post: 11/29/2006, 11:26 AM
  5. No fan or heater HELP PLEASE!!!!!!!!!1
    By 99VX4x4 in forum VX Talk...
    Last Post: 02/01/2006, 09:18 AM
